1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
New PB...... auto
Old May 8, 2009 | 04:37 PM
Grand_hustle17's Avatar
New PB...... auto
So at the last minute i choose to go to the track today, and got a record of 5 runs..
1st run....... never even turned the car off straight off the highway
60' 2.273
1/8 9.926
mph 72.60
1/4 15.336
mph 91.45
2nd still never turned the car off, just went right back... track was empty
60' 2.250
1/8 9.947
mph72.34
14/15.354
mph 91.50
3rd after 30 min break
60' 2.275
1/8 9.784
mph 74.18
1/4 15.084
mph 93.19
4th after about another 30 min break comes the break through
60' 2.249
1/8 9.592
MPH 75.05
1/4 14.855
MPH 93.41
This was a PB in all category (edit) i've actually had 2.1 60's with my 5th gen
and my 5th run i ran 15.0@ something, do know where the hell the slip went
Mods... EBAY 4th gen short ram intake
Old May 8, 2009 | 05:29 PM
321VQ35MAX's Avatar
Good job. It looks like the 1/8 mile is what made the difference on your best run, seems like you got out of the whole much better with less spinning.
Old May 8, 2009 | 05:32 PM
put my rear wheels on the front... noticed the inside of my front tires were terrible... one almost down to the metal lol
Old May 8, 2009 | 05:46 PM
jkpgt96's Avatar
Nice times! Get that 60' down a little more and you are set. But still I would be content with a low 2.2 60' like you had..
Old May 9, 2009 | 04:16 PM
yea, im waiting until i get some kinda of AM lowering kit before i expect any lower
Old May 13, 2009 | 08:57 AM
CMax03's Avatar
try to leave on the yellow!
Old May 13, 2009 | 06:57 PM
yea... i probebly could do a lil better, i havent been to the track in a bit, but ill get it
Old May 13, 2009 | 07:43 PM
CMax03's Avatar
Yeah I'm shooting for 2.0 sec/60ft or below...on street tires, just got the ES motor mounts and subframe/crossmember bushings. I usually run with 25-26 psi in the fronts, turn the Illuminas up to 5 (F/R), and launch @ about 1500 rpm, still working on the power braking method as wells as shifting the automatic manually...
Old May 13, 2009 | 07:47 PM
shifting an auto aint the problem... just look at the rpm needle til its at about 6300 6400 then shift i launch at about 1800-2K rpm did me o.k
Old May 13, 2009 | 11:05 PM
krazy6's Avatar
Your mph seems low for some reason.
In my 6th gen I ran a 9.2 @ 79 in the 1/8. Intake and no vias.
Old May 14, 2009 | 07:17 AM
DandyMax's Avatar
3.5 in the works
Congrats!
Old May 14, 2009 | 10:20 AM
jkpgt96's Avatar
Why? Why not just leave when he gets ready to leave? Your R/T has nothing to do with your ET..just make sure you are ready to launch and then go..
Not for a loaded atx car..You are comparing a 6 spd to an atx..I ran 9.0 @ 80 in the 1/8th..doesn't really make for much of a fair comparison though, now does it...?
Old May 14, 2009 | 06:51 PM
i was aiming for a 94mph... but i guess 93 stock is the norm
Old May 14, 2009 | 10:44 PM
jkpgt96's Avatar
Try like 22 psi in the tires and see if you can launch a little higher..
Old May 15, 2009 | 07:23 AM
i dont have the SE17's, i was on the 5 spoke 5th gen 16's
Old May 15, 2009 | 07:54 AM
jkpgt96's Avatar
...so....?
Old May 15, 2009 | 08:12 AM
...so....?
srry... didnt kno the same procedure apply
Old May 15, 2009 | 11:16 AM
jkpgt96's Avatar
Oh..well, I mean tire pressure changes between a 16 and a 17 inch wheel are not that big, as compared to a say 15 and 19..
Old May 15, 2009 | 02:35 PM
im not sure when will i be at the track again, but ill definately try that... i wanna get my suspension, and a custom exhaust, before i go back
Old May 15, 2009 | 08:15 PM
jkpgt96's Avatar
Gotcha...good luck!
Old May 16, 2009 | 08:11 AM
ill need it... ill then be moreso focused on PB's
Old Jun 1, 2009 | 11:00 PM
Scottwax's Avatar
That's Mr. Detail to you
Because cutting a good light is part of drag racing? Personally, when I used to go to the dragstrip, winning without breaking out was my primary goal once I got my ET dialed in. I don't really get going out to the dragstrip just to see what your car runs, I really like running brackets.
Old Jun 2, 2009 | 06:29 AM
jkpgt96's Avatar
Because from what I am gathering he just wants to see how fast his car is, not how good he is at guessing. Bracket racing is fine, but its your opinion that you like it, it doesn't mean taking your car to the track just to run is stupid. Cutting a good light is only part of drag racing if you really care about beating the guy next to you, or you are bracket racing. You say once you got your ET dialed in..well, he has to know what his car runs first! I run my car to see what it can do and what I can do in it, not what I can do compared to the guy in the other lane. I know here in STL the track only does weekly bracket racing for HS, not for street car. Also, unless he is going all the time, why not just go to see what the car can do..?
Old Jun 2, 2009 | 06:30 AM
denice25's Avatar
great job.... congrats...
Old Jun 2, 2009 | 09:43 PM
Scottwax's Avatar
Can't cut a good light if you don't practice, even when getting dialed in. That's all I'm saying. Part of the fun is not only getting a good ET and trap speed but also cutting a good light.
Old Jun 3, 2009 | 06:53 AM
well, i like bracket racing but like someone said, i wasnt trying to challenge someone else i wanted to see what my car can do... we have a end of year even down here (import vs Domestics) where if i want to enter then it would be bracket racing... i now have my catback, but is still awaiting suspension but i may just take it for a run with the catback and see what it do.... i should be getting headers today...
Old Jun 3, 2009 | 08:00 AM
jkpgt96's Avatar
Maybe that is part of the fun for you..but not for everyone. For me..I could careless. I am trying to make a 13s pass in my stock car, so all I am concerned about is taking my time to make sure I get a good launch, 60' and ET. Once I make the pass I have no intention of going back with it, so working on cutting a good light is meaningless...
Old Jun 3, 2009 | 10:26 AM
however bracket racing seems fun... but im not for that at this point... im trying to get a daily run after everymod just for times like u said... so far
stock 15.0
intake 14.8
I/E ??? might try it out this friday
Old Jun 9, 2009 | 12:44 AM
CMax03's Avatar
You must be one hell of a driver running times like that.... and 100% stock! Let me guess octane booster or an exhaust cut out valve? Not tuned either wow! Some guys are just born to faster runners or good *** drivers! Weight reduction is the only thing you could be altering! Is your car's interior, seats, spare, removed during your track ventures or can you load you car up with your 3 or 4 friends after driving up and down the track and go hang out looking at jumping nipples all nite?
Old Jun 10, 2009 | 05:49 PM
yea, to not only beat a rated best time but to shatter it is special, but i guess weather and altitude and all plays a factor
Old Jun 10, 2009 | 09:01 PM
jkpgt96's Avatar
No, No, and no. The car had/has full interior all of the time, spare/jack included. No octane booster, that stuff I don't touch, no exhaust cut-out. I drove two other people to the track with me that night. Its stock down to the original plugs and transmission fluid (until the other day when I changed them). The car put down high power numbers on a low reading dyno, so the car is definitely part of the equation..thanks, btw.
I plan on shattering my current time next track day..still stock, but better tires (still not DRs/slicks). The DA for the day/time I ran was almost 2200, so there is improvement to be made. The conversion for that DA was 13.65@ 102.4..fwiw.
sorry, don't want to ***** your thread. When are you heading back to the track next?
Old Jun 11, 2009 | 08:59 PM
naw its all cool with me.......... i was suppose to go to the track last week but terrible weather has been buggin me for the whole week, im tryna go tomorro but it looks like rain again............. i am on some better tires also, though its a bit of weight adder... G35 18's VS 5th gen 16's
Old Jun 12, 2009 | 08:07 AM
sho off's Avatar
not bad last time i went I trapped 15.6 @93 on my 6thgen 18's.. Id like a run today. Ill be there on my se 16's..
Old Jun 12, 2009 | 08:39 AM
bring the other 2 16's yo... my tires are ripped to the metal thread and i dont wanna run on 18's... love the 93mph trap
Old Jun 12, 2009 | 01:05 PM
jkpgt96's Avatar
I know how it goes, I have been waiting for the weather to clear also, it has been 2 weeks in a row of rain on test n tune night..Good luck!
Old Jun 13, 2009 | 09:44 AM
well, it was a fail for me again this week and not because of weather... GF wanted to see a damn 7:20 movie (the hangover, which is now the funniest movie in life ) track opens at 5pm so i didnt go... i guess my next runs will be at Maxus, and that will also be the first time i run at that specific track so we'll see and hope for the best
Old Jun 13, 2009 | 11:21 AM
jkpgt96's Avatar
Yeah..it will likely be another week before I make it out, because I am getting the Probe on the rollers and tuning it Tuesday, so depending on how long that takes, I won't have time to get home and get the Maxima and get to the track..
Old Jun 13, 2009 | 12:08 PM
i've never actually dynoed a car before, and i really cant wait to... just wanna see what she got
Old Jun 13, 2009 | 02:00 PM
jkpgt96's Avatar
It can be fun or heartbreaking...just depends on how it goes. I am a test car for a new Cam grind from Colt cams, so I am anxious to see how the car runs on the new cams once it is tuned..should be a decent run for the Maxima...maybe...lol
It was fun to baseline the Maxima seeing as it made very nice stock numbers considering the dyno I go to reads ~5% low, where as the Probe is usually disappointing, lol
Old Jun 13, 2009 | 08:55 PM
after going to a dyno meet... it made me wanna be a dyno junkie
