1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
98 maxima 1/4 mile, 0-60 MPH, trap speed.
Old Aug 20, 2012 | 12:32 AM
blackice0123's Avatar
I just wanted to share my numbers so others can compare.
My maxima has a stock engine, lightly modded air box, cat-back open exhaust with straight-thru glass pack resonator. Also, I recently replaced a faulty knock sensor so timing is optimal for a factory tune. No tuning has been done. I run only premium fuel. Gasoline is Tennessee is pretty much all E5 or E10.
My run was done with outside temp of approx. 75 degrees F. The engine had some heaksoak from previous few miles and being parked twice before the run.
Also had a passenger in the front seat for the second run.
The run was clocked using a GPS speedometer app on my cell phone.
Front tire pressure: 35 PSI
Rear tire pressure: 40 PSI
Tire size: 205/55/R16
Transmission: Auto, letting it shift itself.
Stats:
First run:
1/4 mile time: 15.24 seconds
Failed to log speed for trap or 0-60 mph
Second run: (with passenger)
1/4 mile time: 16 seconds
Trap speed: 85 MPH
0-60 MPH: 9 seconds
My opinion: car seems slow when looking at these numbers, but feels peppy and fun regardless. Got very brief tire chirp when launching.
Old Aug 21, 2012 | 10:32 AM
7speed's Avatar
Pretty good actually for what you have done.
I would go to actual 1/4mi to compare but nice if that app is accurate.
I had auto 4th gen with just cone filter on intake and ran 15.9 @90
Get a ypipe one of biggest mod gain for 4th gens for price.
Old Aug 23, 2012 | 11:27 PM
I plan to make a custom ypipe since i'm on a budget. gonna weld up something crude...should be better than stock by far. not sure when though.
i'll post results if i get around to it.
thanks for the input.
Old Aug 24, 2012 | 06:40 AM
cardana24's Avatar
Blown
If those numbers are accurate (you were not at a track), then you should check for the ghost knock sensor code....your trap speed is low IMO. That was my trap speed with my second gen.
Old Aug 24, 2012 | 10:26 PM
no ghost codes, been checking periodically. recently replaced KS and relocated it to upper intake manifold so i can actually get to it. running premium so not worried about spark knock. car feels peppier since doing the KS. i was not at a track, but it was a service street on my neighbor's property. the street is very long, flat and straight. also the app used gps to determine speed and times. i can't vouch for it's accuracy though. it's just the only way i can currently clock the distance and times.
curious why you mentioned me not being on a track. should my times be faster on a track? reason i ask is because tracks surfaces are ideal, but i don't have any real experience on tracks. please elaborate.
Old Aug 25, 2012 | 04:48 AM
Crusher103's Avatar
yea go to the track cant trust these cell phone things. That Iphone app measured my NA MT car at 500whp in 2nd and 70whp in 4th.......not things im going to trust.
Old Aug 25, 2012 | 06:21 AM
cardana24's Avatar
Blown
Because they have equipment made for timing what you are posting. It would be more accurate.
Old Aug 25, 2012 | 11:41 AM
taz394's Avatar
while running towards the end of the quarter have the passanger sit in the back seat and throw the phone into the front seat .. should give you a few more MPH's
Old Sep 3, 2012 | 03:37 AM
big dave's Avatar
The times and mph seem way off. Mine ran the times in my sig with nothing done.
Hondarydr
Dec 30, 2024 06:15 PM
Finkle
Sep 27, 2015 09:53 PM
Gsantos79
Aug 8, 2015 07:41 AM
niZ
Aug 7, 2015 10:18 PM
RealityCheck
Aug 5, 2015 06:18 AM
