1st Gen: No vaccum advance?
Old Aug 23, 2002 | 10:38 AM
Bleach's Avatar
When I pop off the cap and try to turn the rotor back and forth it is a very sticky and kinda feels like it is grinding. I'm sure its not working that well. My car has a little bit of a misfire when accelerating at the lower rpms. It seems to idle pretty smooth though.
anyhow, I'm sure that I need to fix it so the rotor has smooth action so the vaccum advance can work properly.
Can I fix this myself, or am I stuck buying a rebuilt distributor for $200?
As stated above, this is on a 1984 L24 engine.
Old Aug 24, 2002 | 10:05 PM
Engloid's Avatar
Re: 1st Gen: No vaccum advance?
Try readjusting the TPS.
Old Sep 13, 2002 | 01:37 PM
Bleach's Avatar
Ok, so if I adjust the throttle position sensor on the throttlebody that does nothing for my vaccume advance on the distributor.
I don't understand what the TPS has to do with it
Old Sep 13, 2002 | 03:34 PM
Engloid's Avatar
Re: Re: 1st Gen: No vaccum advance?
Hmmm I was thinking it was a vg30 engine. I guess it has vacuum advance, but not sure.
If you can turn your rotor more than about 1/16" by hand, there's a problem somewhere. Possibly the gear is worn. This can cause problems. If you have a timing light and your timing mark seems to bounce, it's an indication of a worn gear, either on the dist or cam, or both.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
Luev
Sep 30, 2015 11:50 PM
sliptap
Sep 30, 2015 05:57 AM
