Turbo a 2nd gen.
Old Jun 18, 2004 | 09:32 PM
  #121
arsonist63086's Avatar
IIRC, the VG30ET runs a T3, not a T25. T25 is too small (hence why they use two of them on the VG30DETT manuals, and two T22 on the autos). They will work, but they only flow so much at so many PSI.
arsonist: Are you talking about boosting your current car, and putting the 300zx Turbo auto ECU in or just running the 300zx Turbo auto ECU? If you try to run that ECU on an N/A motor, chances are your going to run really rich...which will make you loose power instead.
S
i was planing of geting a 300zx non turbo moter and then puting a turbo in it, i was planing of doing this cuz i whant to get the most boost out of the none turbo moter. cuzz im going to the junk yard on the 20 and if i dont find a good turbo motor i was going to get a non turbo moter and get the turbo charger,intacke manifuld,fule reil, and ecu from a f-up turbo moter and but in on the non turbo moter.
i was wondering if i do that will i get into any trubel doing that?
Old Jun 21, 2004 | 12:14 PM
  #122
Drjmaxx88's Avatar
arsonist63086:If you can find a junkyard turbo engine get it. It's cheaper than making a N/A a turbo. Fix the engine,and turbo if needed and go from there.
maximase86:I want to get a T3/T4 hybrid with ceramic bearing. I found the place to mount it so I get the exhaust from both sides of the engine.Now must find a place to put the wastgate,custom make the down pipe needed.
Still debating on whether or not to get it intercooled. May just leave that for a future project.
Running it with 6psi will still put me back in my seat and allow me to tune.
Old Jun 21, 2004 | 05:35 PM
  #123
maximase86's Avatar
I love lamp.
I would say leave yourself a way to add it in the future. You should be okay at 6 psi. I'd start worrying once you get higher than 8 psi. I'm thinking of doing an intercooling setup similar to what you find on the WRX. Have intercooler near the top of the motor, or over the driver side with a small hood scoop to force air through the intercooler. But I'm also thinking of a FMIC too, but I don't want to ditch my A/C, it works great and I use it (even in the winter to defrost the windows). So I'm gonna have to think on how to make it work without it sticking out.
S
Old Jun 22, 2004 | 04:54 AM
  #124
wylie-c's Avatar
A 300ZX scoop would look sweet.
Old Jun 22, 2004 | 07:07 AM
  #125
maximase86's Avatar
I love lamp.
I'm thinking so too. The 84-86 Z31's that have em are square enough that it would go with our cars pretty well. But I'm still wondering on it. I'm also thinking AWIC, sort of like on the Cyclone/Typhoons, but that's going to be pretty spendy too.
S
Old Jul 12, 2004 | 01:34 PM
  #126
Drjmaxx88's Avatar
HEY
I was researching some stuff for the turbo. I read about guys using the 93 pathfinder intake manifold. There seems to be an issue of clearence with the hood. So even if i could get it to fit would it be worth the effort?
Old Jul 12, 2004 | 01:41 PM
  #127
Jeff92se's Avatar
I'm needing a caw
There are 1-2 guys using the AWIC. Expect to spend over a grand to use this. I would rather use water/alcohol injetion
Old Jul 22, 2004 | 01:30 PM
  #128
Drjmaxx88's Avatar
I got a quote for the down pipe from the nissan dealer they said about 140$. Im not sure 140 for something that I'll probably have to modify neWays.
I should just get the front exhaust manifold first.
Is there a way to get the 02 sensor hole in the manifold to fit a wastegate? Since the new one will be after the turbo I just thought why plug it up.
One more thing:been looking at the MAF from JWT will that work for our cars(at all,with/without there ECU)?
Old Jul 22, 2004 | 03:19 PM
  #129
Cutler's Avatar
no no no no no
Old Jul 22, 2004 | 04:37 PM
  #130
Drjmaxx88's Avatar
Damn you are right. thanx for the answers, usually all get from this site is more questions :P
Old Jul 22, 2004 | 07:21 PM
  #131
maximase86's Avatar
I love lamp.
Don't go to the dealer. I mean...unless you want to needlessly waste your money, you can get decent used parts, or brand new parts through other ventors.
S
Old Nov 5, 2004 | 09:01 PM
  #132
KALSC's Avatar
Anybody in Canada want to buy the Turbo Maxima project car? I am seriously looking to unload EVERYTHING I have for this. If anyone is interested, email me at igauaga@telusplanet.net. :-)
I mention Canada as that makes it easier for someone to get the car. If anyone from the US wants to make a deal, we can work something out like either you come get the car, get it shipped or something like that.
Old Jan 8, 2005 | 06:25 PM
  #133
imported_Max_Speed's Avatar
I know im was thinking about the turbo thing but i jus dont have the cash
Old Jan 12, 2005 | 11:40 AM
  #134
Big_E-Dog's Avatar
2nd Gen Boostinator
how come we just cant slap a turbo on the engine we have already
im thinking of slaping a custom supercharger to it it cant be that hard just need to wrap the pulleys around it and connect a few cables i think that the tirbo would be easy also if i saw the setup i could mock up something verry easily not that im saying that ppl are slow but i just think that way mechanical things come verry easily to me.
Old Jan 12, 2005 | 11:41 AM
  #135
Big_E-Dog's Avatar
2nd Gen Boostinator
because if im not mistaken turbos and supers just dump air into the engine right??? or what?
Old Jan 12, 2005 | 12:45 PM
  #136
maximase86's Avatar
I love lamp.
There is much more to boosting than just simply slapping in a turbo or an S/C. And if you don't understand what a turbo or s/c does....you shouldn't try to stick it in your car. :P
S
Old Jan 12, 2005 | 12:50 PM
  #137
Drjmaxx88's Avatar
you are correct sarin.
Old Jan 12, 2005 | 12:52 PM
  #138
maximase86's Avatar
I love lamp.
Yes I am! I've worked with boost for a couple years now....and the most important thing when working with boost is knowledge.
S
Old Sep 13, 2005 | 11:01 PM
  #139
DJ Technischer's Avatar
I am going To turbo my 1988 maxima soon , Just really dont know where to start , By Installing turbos on my current engine with 140k Miles ," Witch i would have no clue Witch 1988 300zx turbo , Then i would need a list of all The parts and How to install it , So i have no clue what to do!
Old Oct 20, 2005 | 01:46 PM
  #140
Pickles's Avatar
go turbo go go go
Old Nov 3, 2005 | 10:21 AM
  #141
shaughn's Avatar
i like that this was brought back from the dead. *snorts*
so far people just get the 300zx parts and throw them in. or you have swapping an engine.
my plan?
just make a custom kit for the maxima.. haven't deceided whether it be a fmic or tmic (like on wrx's or such). Both would need body parts modified most likely.
the turbo? it being a 3.0l and I only plan on going to 14psi, t3/t4 hybrids, or looking at 13b or such mitsubishi turbos.
We'll see how it goes. Right now i'm doing a complete custom interior.
p.s.: if anyone says it'll be easier to swap an engine. Don't. I've turbo'd many vehicles in my past.
eg.
88 240sx-turbo
93 3000gt vr-4 (just upgraded/rebuilt everything)
89 Escort GT-turbo
95 Neon-turbo
95 Mustang S/C
93 Jimmy-Turbo
Old Nov 5, 2005 | 01:32 PM
  #142
Big_E-Dog's Avatar
2nd Gen Boostinator
well ive been looking at intercoolers at other cars from the junkyard such as:
talon/eclipse
thunderbird turbo coupe
saab 900 turbo
audi (dont remember)
turbo escort GT
and the one that looks like it would work the most would be the the saab with the 300zx hood scoop like the setup i had would look killer with a intercooler under it, even so the hood scoop from a 200sx turbo with the opening opened up would prolly look cool as well.
i have a kit on stand by at the local junkyard kit includes
a couple of intercoolers
84 300zx turbo (T3 i think)
300xz turbo exaust manifold
volvo turbo piping
300zx turbo injectors
300zx turbo MAF
300zx turbo ECU
volvo boost gague
volvo BOV from a 740 like a 88 (dont kno what it is rated at tho) Does ne one kno??
all of this is gonna cost about 250-300 bones unless i get it on a 50% off sale i missed the last one but ill forshure get the next one.
just gotta make those custom motormounts or buy them from KALSC if hel make them for me, "hint hint", other than that ill need a 85-88 maxima 5 speed in the southern cali area and ill be good to go
Old Nov 8, 2005 | 06:42 PM
  #143
theoldboy's Avatar
Guess I'm kinda lucky as my 88 legran come with a turbo stock
I'm from downunder .and only recently bought one ,its definatly grown on me drive it all the time now
the engine is a VG20ET 2L V6 Turbo, pretty quick stock even with a messy looking intake setup .Runs through a 4 speed auto
You could look at getting this engine from Japan might save a bit of work
looks about the same size as the 3L
hope I can find out more info on your site as there is bugger all down here in Australlia thanks Dave
Old Nov 10, 2005 | 02:16 PM
  #144
Big_E-Dog's Avatar
2nd Gen Boostinator
could you get parts for me, like exayst down piping from the turbo to the exaust and the front engine mount???
Old Nov 26, 2005 | 03:36 PM
  #145
will_john's Avatar
i agree totally
Old Dec 6, 2005 | 03:02 PM
  #146
ozziemax's Avatar
guys need help toi boost my babymax
hiya, man am from australia. need a 5 apeed conversion kit for my car where can i get the full assembly. any help where i can buy one.. thanx ozziemax
Old Mar 8, 2006 | 05:26 PM
  #147
jp50662's Avatar
What turbo should I swap the turbo that comes with the car stock to, without doing engine mods?
Old Aug 31, 2006 | 07:46 PM
  #148
Big_E-Dog's Avatar
2nd Gen Boostinator
Originally Posted by KALSC
Well, there are quite a bit of variables to consider when I did this swap. Consider:
1. I had the tubro rebuilt, you may not
2. I had my cams ground, you may not
3. I had the heads professionally rebuilt, you may not
4. I did a complete clutch job, you may not
5. I installed a 60mm 240sx throttle body, you may not
6. etc., etc.
What I will be doing is a complete breakdown on the website I put up insofar as costs involved so people can discern for themsleves the different cost levels.
As for horsepower, no idea. I do know that it's impressive. At some point when I get the tuning done, I will probably have the car dynoed and then I can let you know HP at the wheels.
Food for thought, I am in the process of making up a bunch of the parts needed for this kind of swap. Parts like: turbo dump so it matches up to stock flex pipe and clears starter, custom mount to mount first or second turbo at exhaust crossover. I am also installing a blowoff vlave this weekend. Those too and the fitting for it will be available, specific for this install. The blowoff valves are sweet, pics coming soon. Also, the custom motor mount needed. The one I made up is working out great so far.
Anyway, I will make some stuff available to those who are interested in getting the oddball parts together to do this swap.
Anyway, I'll keep you guys posted on everything and my website will be getting a healthy update pretty soon.
Cheers!
i need those motor mount ant exaust downpipe if avaliable pm me with a quote
Old May 16, 2007 | 09:17 PM
  #149
208max's Avatar
can i use da vg30e's ecu on da vg30et
Old May 21, 2007 | 07:32 PM
  #150
maximase86's Avatar
I love lamp.
The pinout on the turbo ecu is slightly different, while it might work, you are going to have problems unless you change the pinout or the harness.
S
Old May 24, 2007 | 09:05 AM
  #151
208max's Avatar
well ok but i have another problem i want to use the z31 clutch and pressure plate but it won't fit da maxima's flywheel but i don't think i can use da z31's flywheel cuz my starter will not make conetact with it or am i wrong can i get some help with this
Old May 24, 2007 | 07:51 PM
  #152
Big_E-Dog's Avatar
2nd Gen Boostinator
it wont fit because the 3000zx trannys are totally different (longitudal instead of compact) so just use the regular max stuff upgraded look on e-bay and youll find some stage 2 clutches
Old May 27, 2007 | 12:47 PM
  #153
208max's Avatar
ok thanx but i have another query i have the 84 300zx ecu and the engine dat i have is of a later model i think it is 85-87 cuz the t3 is water cooled and i would like to know if the engine will work with this ecu
Old May 27, 2007 | 03:10 PM
  #154
max95q's Avatar
Its been a while since I have been in here but didnt we need the same year as the maxima we had in order for it to work on the Maxima?
Old May 27, 2007 | 04:30 PM
  #155
Big_E-Dog's Avatar
2nd Gen Boostinator
my guess is no because the year change they might of changed sometin in the ecu but if it was te other way around then it might work
Old Jun 9, 2007 | 06:31 PM
  #156
208max's Avatar
i am having a problem with starting the car is swinging but i am not getting electricity in the distributor what could be the cause of this ??
Old Jun 9, 2007 | 09:27 PM
  #157
Big_E-Dog's Avatar
2nd Gen Boostinator
the coil its behind the left drivers side or your timing is waaaaaaay off or no connectors connected
Old Jun 10, 2007 | 07:19 AM
  #158
208max's Avatar
the connectors are connected so i should check the coil and the timing
Old Jun 10, 2007 | 07:47 AM
  #159
max95q's Avatar
There you go.
Old Jun 10, 2007 | 11:47 AM
  #160
Big_E-Dog's Avatar
2nd Gen Boostinator
btw how do you know that your not getting electricity from the distributor?
