Shifter problem
Old Jan 26, 2003 | 10:58 PM
ksultz's Avatar
Shifter problem
My shifter will not lock into place... I can move it from drive to neutral just by bumping it. A real problem if I'm driving it at the time. Anyone run into this problem...if so...what's the fix?
Old Jan 26, 2003 | 11:30 PM
maximase86's Avatar
I love lamp.
Re: Shifter problem
Ummm, that is normal for automatics to do that. As long as you can't go through reverse by bumping it, or down by bumping it your fine.
S
Old Jan 29, 2003 | 10:03 PM
ksultz's Avatar
Re: Re: Shifter problem
S
It does go throught reverse also...I can move the shifter from reverse through neutral and drive with out using the shift button. the shifter does not lock/click into place in reverse or drive... I have to be real careful when putting the shifter in reverse or drive...alot of time it stays in neutral and I have to move the shifter and reposition it several times to get it into drive or reverse.
Old Jan 29, 2003 | 10:47 PM
maximase86's Avatar
I love lamp.
Re: Re: Re: Shifter problem
I would then do an inspection of your shift linkage. The lock lever could be worn down or broken.
S
Mar 12, 2020 12:06 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
lux97Max
Sep 28, 2015 11:18 PM
ef9
Sep 10, 2015 10:35 PM
