Another clutch question
Old Jan 29, 2003 | 02:40 PM
MrSmith's Avatar
Before my car went into its comma, I was driving and the car drove fine, then the car just cut off , I would periodically try to start it without success and it's been sitting sence then. It's been about 2 years now and I finally got it to start. Well the things that worked before for some reason dont work now. For one thing, When I press my clutch in I get nothing. It just goes in without any effort. Before the car died I had no Clutch problems , but now that it sat for so long I have no pressure. What could this be?
Old Jan 29, 2003 | 02:43 PM
Jeff92se's Avatar
I'm needing a caw
No fluid in the clutch master cylinder
Old Jan 29, 2003 | 02:46 PM
MrSmith's Avatar
Plenty of fluid, In fact I changed it. I also checked the lines and they arent leaking and are free. which way does the lever on the slave cylinder go when you press in the clutch left or right?
Old Jan 29, 2003 | 02:54 PM
Jeff92se's Avatar
I'm needing a caw
Looking from the front of the car, to the driver's side. Maybe the m/s is bad now. Try pumping it repeatedly and see what happens
Old Jan 29, 2003 | 03:01 PM
MrSmith's Avatar
I did that to. I pumped slow and fast, I removed the lines and pumped , I removed the slave cylinder and pumped and I dont have any leaks. I topped off my clutch fluid then pumped somemore. I dont get it, before it shut off I had no clutch problems, so it's hard for me to think its enternal
Old Jan 29, 2003 | 03:04 PM
Jeff92se's Avatar
I'm needing a caw
Okay now try bleeding it. hehe
Old Jan 29, 2003 | 03:07 PM
MrSmith's Avatar
blood
I dont have any pressure, How bleedeth thow this
Old Jan 29, 2003 | 03:18 PM
Jeff92se's Avatar
I'm needing a caw
Re: blood
Well open the bleeder valve on the slave and see if you can get the fluid to flow out when you push the pedal down.
Old Jan 29, 2003 | 03:24 PM
MrSmith's Avatar
Sounds like a plan, Ill try tomorrow before I go to work. Ill have to get one of those Nobody helpin you bleeders, Because it aint nobody helpin me do it. What if air comes out, would this build up pressure in the peddle??
Old Jan 29, 2003 | 03:28 PM
Jeff92se's Avatar
I'm needing a caw
If nothing comes out and you have fluid in the resovior(sp?), that means your master cylinder is probably dead or needs to be primed
Old Jan 29, 2003 | 03:30 PM
MrSmith's Avatar
What I did was remove the line from the master cylinder and pressed the peddle. When I did this the fluid came out with each press.
Old Jan 29, 2003 | 03:32 PM
Jeff92se's Avatar
I'm needing a caw
Then the slave cylinder is probably all gunked up.
Old Jan 29, 2003 | 04:08 PM
MrSmith's Avatar
Yeah your probably rite. I didnt see if fluid would come from it, What I did was press the slave thing and I saw the fluid in the resovuor(sp?) rise. But didnt see if fluid would come from the bleed valve its self. Ill try it, By the way. If I step on the peddle which direction does the lever move on the slave cylinder?
Old Feb 3, 2003 | 11:43 PM
MrSmith's Avatar
Thanks!!
Well I changed the slave and had to change the master again and then I had slight pressure, I bleed the lines and It got tight. So I guess Im good to go
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
Johnny9595
Sep 3, 2015 05:18 AM
