88 maxima intake
Old Jan 21, 2001 | 04:41 AM
brianspaz
Since the 88 maxima and the 88 300zx have the same engine will the intake from the 300zx work on the maxima I believe the only problem is the engine is turned different.
Old Jan 21, 2001 | 06:07 AM
maxima561's Avatar
What part of the intake are you talking about? The intake manifild or just the section before the maf? You wanting to hook on a k&n or something like that. If so check out my web page http://skyboom.com/mattbender/newmax.htm
Old Jan 24, 2001 | 02:28 AM
For this swap to work you have to make sure that your injectors are color coded the same in your car and the 300zx. Furthermore, the injectors are usually matched to the ecu. An ecu with a different serial number may actually burn the injectors. Injectors may be calibrated diffent.
MAXSE5SPD
Aug 23, 2015 12:06 PM
cheftoo
Aug 20, 2015 05:17 AM
MaxStock
Aug 12, 2015 08:33 AM
Maxboy23
Aug 11, 2015 11:59 AM
