Lubricating throttle cable tensioner springs (or whatever they're called)?
Old Apr 30, 2003 | 07:12 PM
electric!sheep's Avatar
My gas pedal started catching recently, so I took a look at the spring-tensioned device the wire attaches to on the (throttle body?) and discovered a load of grime and dirt all over. Not knowing exactly what to do, I removed the metal guide-unit for the wire (breaking the aged plastic outer spring spacer and bracket in the process ), brushed the springs a bit and added some general-purpose household lubricant, but it's not quite doing the job (smoother overall, but still sticks sometimes). Apparently I need something thicker, or the problem lies elsewhere.
Just for starters, what oil should I use, if any? I have some thick chainsaw bar and sprocket oil , motor oil, or maybe I need to go out and buy something (elbow grease?). Does it really matter, as long as it doesn't flow away/break down? Secondly, would it be wise to squirt a little oil right where the rotating bar (that's turned by the wire & springs) enters the throttle body (??), just in case something is sticking there? Lastly, are the outer plastic spacer and bracket all that important? The spring sits just fine, if a bit off-center due to the missing bracket. I'll go to a junkyard and find the parts sometime, but the question is when do I need to do it.
</end n00b post>
02PearlSE
Feb 1, 2016 12:37 AM
knight_yyz
Oct 24, 2015 08:05 AM
pktaske
Sep 4, 2015 08:40 AM
