87 Maxima - A/C debris-goes where?
My 87 Maxima's A/C is ailing even after adding 1.5 pounds of R-12 freon. Cooling is much better after service, but not like before.
The A/C inlet screens near windshield often fill with leaves/blossoms from overhead Oleander trees. Some debris falls past the plastic screens inside the A/C. Does this debris collect in the A/C internals or does it travel down and out some vent at bottom?
Is the debris possibly degrading the cooling?
Can I clean this debris or is this something
an A/C shop MUST DO?
My 87 owners manual is not showing any deris collector or path or vent.
Thank you, Dave
Thank you, Dave
Re: 87 Maxima - A/C debris-goes where?
Thank you, Dave
Thank you, Dave
S
Re: Re: 87 Maxima - A/C debris-goes where?
Originally posted by maximase86
Well, most of that stuff would most likely be sitting at the bottom of the vent inlet right now.
I thought so.
Does air movement in the car seem to be an issue?
No, plenty of air is moved.
Not sure how to do you recommended procedure.
Thanks, Dave
S
I thought so.
Thanks, Dave
S
Re: Re: Re: 87 Maxima - A/C debris-goes where?
S
kirkhilles
Aug 8, 2015 10:53 AM
