I should have bought the Commodore
Old Jun 3, 2003 | 05:06 PM
markosmith's Avatar
Hi guys,
The fuel injectors from my 2.0i V6 '88 Max have broken. Does anybody know where I can get new ones from. So far the mechanic has only found 3.0i injectors. Is the only option to import parts from Japan, or are there substitutes on local Australian cars?
Old Jun 3, 2003 | 07:03 PM
maximase86's Avatar
I love lamp.
I would assume that there isn't much difference from the VG30E and the VG20E injectors. Most likely your gonna have to import them...I'm not sure what other cars came with the VG20E either, so maybe finding what other car has that motor would be a good shot.
S
Old Jun 3, 2003 | 07:12 PM
markosmith's Avatar
Wouldn't the injection levels be different between a 2.0 and a 3.0i
Old Jun 3, 2003 | 08:02 PM
maximase86's Avatar
I love lamp.
Yeah, but even so, they should work. I know that you can use VG30DETT injectors on pretty much any Nissan V6, and some of those injectors run 555cc per minute etc. If your planning any sort of performance modifications with your car, it would probably be a good idea to consider the VG30E injectors.
S
Old Jun 9, 2003 | 11:17 PM
markosmith's Avatar
What sort of impact would installing one VG30E injector in with 5 VG20E injectors have on my car?
Old Jun 10, 2003 | 07:55 AM
maximase86's Avatar
I love lamp.
That would probably be a bad idea. Generally the rule of thumb is if you place one injector, you want to do all of them. You definately don't want to mix them either because it can cause some bad performance problem, like one cylinder running too rich or too lean compared to the rest of them. It can cause the motor to run pretty rough.
S
Old Jun 10, 2003 | 08:09 PM
markosmith's Avatar
Yeah that's what others have said. Any idea on how much it'd cost to replace them all?
Old Jun 10, 2003 | 08:57 PM
maximase86's Avatar
I love lamp.
Well, in the US, I believe it's upwards of $300 or more I believe...but don't hold me to that. Anyone else got better numbers?
S
Old Jun 10, 2003 | 09:04 PM
Charles Bisel
The dealership that did the recall on my car said it would have cost me around $750-1000 USD for the injectors, harness, and labor if I had it done without benefit of a recall. Now, if you do it yourself and don't replace the harness, then it would be cheaper, maybe around $300 as Sarin mentioned for new injectors. If you're going to go with different injectors though, you may need to replace the harness and possibly the fuel rail, I'm not sure.
-C-
Old Jun 10, 2003 | 09:59 PM
markosmith's Avatar
Thanks for your help guys
Old Jun 11, 2003 | 01:26 PM
John L's Avatar
Try getting in touch with George Merryweather (gmerry1@airmail.net) Of Classic Restorations (www.classicr.com) in Lucas, TX. He mostly caters to the British car crowd, but he is a Victoria Bitish distributor who has a Z car catalogue. Part # 57-103 fuel injector, 300 ZX '84-'86 59.95USD x 6. Part # 20-3104-Z 300 ZX '87 49.95USD ($10 core)X 6. Part #20-3105-Z 300 ZX '88-'89 49.95USD ($10 core) X 6. Part # 57-200 fuel injector seal kit 280-300 (all) 6.95USD.
1AUD = .66USD at today's exchange rate.
G'day
Old Jun 12, 2003 | 05:36 PM
markosmith's Avatar
Thanks John.
Will do
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
