Hey guys, been driving around and the last few days have been pretty hot. I've been using my A/C a lot since about thursday or so. My question is, is it normal to have water leak on the the passenger size floor. There isn't a ton of it, but enough to drip maybe a small cupful on to the carpet. I felt up in where area where the water was coming from. There seems to be a tiny bit of standing water there. The water is a little dirty, but that's probably from the dust and what not in the system. I'm thinking that since I was using it so much that there was a lot of condesation that the pan that holds that became overfilled. I don't think it's r-12 coolant, what you guys think?
S
S
Well on the bottom of our cars should be a small clear plastic tube that comes out of the bottom and it sends all the water down to the ground. You may have lost yours.
Quote:
Or the outlet may be plugged...Originally posted by max88q
I've cleaned the outlet before on other cars with a
metal coat hanger.
Be careful when you clean it out though... there's a
core in the box that can get damaged easily.
I'd find the outlet tube, and with the engine running and
A/C running, push up in the tube with the coat hanger (stop
if you feel a lot of resistance) and see if water starts
coming out.
Hope this helps...
Scott
both of the first 2 posts are right. 9 out of 10 your condensate drain is plugged. I do heating and air conditioning for a living in the military and its all the same principal. Unplug the drain and you should be straight. It doesnt matter how long you run your A/C, your condensate pan should never fill with water to the point it gets on the carpet. Keep us posted if you get it fixed.
Jose
Jose
Will do, I just need to find time to do it, as well as where the drain is. I will get back to you guys on that.
S
S
The drain should be visible from underneath the car. It should be a strange looking clear plastic tube like it shouldnt be there. But its your drain tube.
well i think you should just give up A/C and pull the compressor and send it to me?
have you had any work done to it? any conversions to the cheeper "safer" freeon and new compressor?
ummm....wtf? I ain't pulling out a system that works fine and selling it. :P My condensation pan was clogged, that's ***. :P
I had the same problem.
Ended up dismantling the A/C Box inside the car and found Lots of Wet Dust Bunnies on the coil. Cleaned with small Shop Wac rubber brush/tube and cleaned the plastic pan too. LOTS of Krud. Drain pipe clogged as well. Cleaned it out and on occasion use a 3" coat hanger to keep the drain hose open Located on firewall behind engine near the Power steering tank.
Chrisjohnson
Chrisjohnson
