sputtering/backfiring
Old Nov 20, 2003 | 05:56 AM
cardana24's Avatar
Blown
this am when warming up the my 87 Max before going to work, I was noticing that it was sputtering/backfiring until it got up to temp....just wonding if anyone has had any experience with this....the noise that is it making not loud at all, just sounds possibly like it is missing every once in a while....very low pitched like "thoooop" "thooop"....lol thoop....any help would be appreciate...I will probably just change the plugs and hope that helps.
Old Nov 20, 2003 | 06:59 AM
alllw86's Avatar
Check for any errors code from the ECM.
Read Pkfinn's post and link in the "sticky" section on the air regulator. That air regulator acts like a choke, mine could not be fixed but new one only $65.
Al
Old Nov 20, 2003 | 10:04 AM
maximase86's Avatar
I love lamp.
My car will make the light thoop sound every now and then when cold. You can probably do some timing adjustments and tune up. Also check the operation of the EGR valve. The air regulator could also be the reason it's doing that. As the frequency of the sound is excessive, you probably won't have too much to worry about.
S
Old Nov 20, 2003 | 10:25 AM
cardana24's Avatar
Blown
ok thanks, I plan on checking my ECU tonight for any codes...I imagine I will have a few I am also going to do a tune up tonight...I just got oil/filter, air filter, plugs, wires (advanced auto brand?)...so hopefully that will smooth things out a little bit...if not I will look into that air regulator
Old Nov 20, 2003 | 12:38 PM
maximase86's Avatar
I love lamp.
Oh yeah, be prepare to curse at the oil filter location....it's on the back side of the motor. I guarantee a PITA to get to. :P What kinda plugs you get? I usually like to stick with NGK stuff for the ignition myself.
S
Old Nov 20, 2003 | 07:09 PM
max95q's Avatar
S
I agree its an easy spot, to a point. Sometimes theyll come out easy from the top other times youre ready to curse at it.
Old Nov 21, 2003 | 08:58 AM
cardana24's Avatar
Blown
Al
where did you get your new air regulator?...did you get it at a junkyard/nissan/parts store?
Old Nov 21, 2003 | 09:12 AM
maximase86's Avatar
I love lamp.
probably can find one at a parts store. Most likely they will need to order one however.
S
Old Nov 21, 2003 | 12:04 PM
cardana24's Avatar
Blown
S
I got the NGK copper plugs...and I got advanced auto plug wires, I got a pure-1 puralator oil filter, and just some Shell 10-30 oil, and a puralator air filter...I want to get an intake so I did not get a K&N drop in since I will be replacing it soon....I want to do cap and roter too but I did not have the money...maybe next week
Old Nov 23, 2003 | 02:37 AM
FanaticMadMax's Avatar
Curse at the oil filter, that crack me up. Well I know how much it's a pain to get there when you have a hot engine.
