plugs
Old Mar 21, 2004 | 01:57 PM
Kman87240's Avatar
plugs
what are the best plugs for our engines?
Old Mar 21, 2004 | 03:25 PM
maximase86's Avatar
I love lamp.
I would probably have to say NGK V-Resistors. That's what I've been using in my car. In all reality, an NGK plug would work best. I just like the V-Resistor personally but any copper, platinum or iridium plug from NGK should work fine.
S
Old Mar 21, 2004 | 05:49 PM
wylie-c's Avatar
Running the same plugs here too, NGK V-Power. I wouldn't run platinums in an automatic though. The engine in an auto is always lagging ( steadily cruising at very low rpm's ) more than in a 5 speed, and tends to foul up the platinums. But if you've got a 5 speed, and don't lag the engine, the platinums should work well. I don't know anything about the iridium plugs though.
Old Mar 22, 2004 | 11:44 AM
Kman87240's Avatar
ok thanks cause ive got bosch platinums, 1 not 4(4 is a waste) And now after a while i have a miss under load and under hard acceleration. so, hopefully these help. if not then guess i'm gonna have to go start replacing injectors, fuel filter, plug wires, dist cap, rotor, the whole nine.
Old Mar 26, 2004 | 10:58 PM
Kman87240's Avatar
changed plugs and tada miss gone.... my platinum plugs are ****ty the electrode or what ever you call it in the middle was fried and receded down in the outer part.(sorry about my spark plug vocabulary). but im happy that my miss is gone, engine kicks *** again. i went ahead and took a few more bucks and bought some octane boost and advanced my timing to 25 degrees, which.... by the way made it pull a bit harder from 3-4 1/2. I mean once it hits second gear it jumps to 70 real quick.
BOSCH PLATINUMS--- :
NGK V POWER--------
Old Mar 28, 2004 | 08:34 AM
blackmaxima88's Avatar
yeah don't be fooled... I got those bosch platinum 2s when I first got my max, and they were absolutely horrible. I've had better luck with them in my other cars, but not either of my nissans.
Old Mar 28, 2004 | 06:01 PM
maximase86's Avatar
I love lamp.
Yeah, general consensus is go for the NGK plugs.
S
Old Mar 29, 2004 | 07:53 AM
MaxWgn's Avatar
Agreed...I used the AC-Delco Rapid Fires in a previous cars with a great deal of success, but they missed on my wagon...replaced with NGK's, and miss is gone...
Old Mar 29, 2004 | 08:33 PM
Drjmaxx88's Avatar
Which wire set would you guys use with the NGK?
Will a hotter plug and wire combo end the rich fuel condition, or is it just the tip of the glacier?
Will a tune up aleviate this or are all these steps just small in comparison with a real problem?
Old Mar 29, 2004 | 09:15 PM
maximase86's Avatar
I love lamp.
I'm using an NGK wire set myself. As for using a hotter plug, that may help, but I can guarantee it.
S
Old Mar 29, 2004 | 09:35 PM
Kman87240's Avatar
yes yes NGK all the way, somehow, im getting better gas mileage, maybe since im not missing anymore the engine isn't dumping in and irregular amount of fuel, i just drove to cinci and back today and everything is great. by the way anyone here from cincinati OH? cause i was cruisin all over there today, nice clean town...
TKHanson
Nov 24, 2018 01:39 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
