Sun roof window
Old May 25, 2004 | 10:21 AM
Quiro162's Avatar
Sun roof window
Does anybody know where is the fuse located for the motor that opens and closes the sun roof window?
I opened it and now it does not want to close.
Any suggestions?
Old May 26, 2004 | 02:13 PM
Kman87240's Avatar
there is a manual screw turn right above the rear view mirrow incase you cant get it in and it stars to rain. just check under the little plastic peice.
Old May 28, 2004 | 06:37 AM
Drjmaxx88's Avatar
I checked under the plastic. Is there another cover or something? All I saw was a black rubber button.
Old May 28, 2004 | 08:26 AM
86Wagon's Avatar
It should be under the map lights just in front of the sunroof.
You'll need to remove that housing assy (not sure how) and
there is a spot to put a wrench (allen wrench I believe) there
to manually close the roof.
Scott
Old May 28, 2004 | 08:31 AM
Drjmaxx88's Avatar
Thanx
I'll check it at lunch
Old Jun 29, 2004 | 02:28 PM
Drjmaxx88's Avatar
Mine has a space for a flathead screwdriver. And I still cant close it I think I just take the whole assembly apart and try to manually shut it again.
Old Jun 30, 2004 | 12:05 PM
6re99's Avatar
mine has stopped working before, you just need to keep tring to close it and it will eventualy go. Does yours make a 'click' sound when you press the button in? Mine did, but after a few minutes or so, and turning the car on and off, it finaly went.. good luck
Old Jun 30, 2004 | 12:21 PM
Drjmaxx88's Avatar
Yeah it makes that noise. I took it apart like a year ago trying to get it to close. This time i'll get it right.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
Luev
Sep 30, 2015 11:50 PM
