size of hoses around the gas tank
Old Jun 22, 2004 | 05:29 PM
Geza's Avatar
The vent hose of my gas tank is leaking gas every time I fill up the gas tank. So, I want to replace this hose, but I don't have a clue about the size (i.e. diameter) of it. My guess is that it is about 8mm, but I am not sure.
Does someone here know what diameter are the 3-4 short hoses (including the vent hose, to the tank-neck)?
I'd hate to lower the tank and remove the hoses just for measuring the size, then put the whole enchilada back, go to the parts store by the right hose then do the whole thing all over. I only have one car.
Geza
Old Jun 22, 2004 | 07:48 PM
maximase86's Avatar
I love lamp.
I have no idea of the size, but you should just lower the tank and take off the hose. Once you got it measured, you can just put the new hose back in.....just requires another means of transportation.
S
Old Jul 2, 2004 | 01:07 AM
Pete Shafer's Avatar
Geza
I don't recall the size of each individual hose but Ican tell you that I recently removed my fuel pump,dissassembled the fuel pump/sending unit carrier, replumbed the whole deal and installed an inline pump under the car. I bought 4 ft. of 5/16 and 4ft. of 3/8 and had some of each left over when I was through. And by the way, you don,t have to drop the tank at all, access for the gas tank is possible under your back seat. I did the entire job I just described WITHOUT dropping the tank. Good Luck, Pete
Old Jul 2, 2004 | 01:10 PM
Geza's Avatar
Pete,
Thanks for your valuable ($225) but late tipp, I made a weak attempt of removing the fuel tank last weekend, but I gave up on it because I was doing it on the street and it was just too much of a task to do such work on the street.
So, I ended up taking the car to a AAA aproved repair shop next to my workplace and they did it for $225 (labor:$100, parts: $125 including tax), that I think was a major rip off for a few OEM made rubber hoses, not mentioning the labor cost if you can really do the whole thing without removing the fuel tank, it shouldn't take more than an hour if you have a hoist.
Again, thanks again for the great tipp,
Geza
San Fernando Valley, CA
Old Jul 5, 2004 | 02:45 PM
Pete,
Geza
Geza,
Your right, if all they had to replace were the hoses then you did get 'hosed'. There may have been broken steel passthrogh lines in your sending unit however and if that be the case you got a fair deal, IF that be the case. Pete Shafer
Old Jul 6, 2004 | 06:26 AM
MaxWgn's Avatar
Anyone replace a pump on a wagon? Mine's starting to whine, so I'll be looking at this repair soon, it seems, in addition to the other stuff I gotsta fix...
Old Jul 6, 2004 | 10:39 AM
Geza's Avatar
MaxWgn,
clogged fuel filter can also cause louder fuelpump noise, have you already replaced it?
Geza
Old Jul 7, 2004 | 12:26 PM
Drjmaxx88's Avatar
I found the leak today but suspect its been there for awhile now. Bad gas mileage only when I fill up the tank. I saw as I parked my car. Under the driver side rear bumper. It was just dripping a litte pile of gas. So how much hose do you need to fix this? What was the seal you metioned?
Old Jul 7, 2004 | 02:04 PM
MaxWgn's Avatar
Nope...not yet...that's my next lil project...
MaxWgn,
Geza
Old Jul 9, 2004 | 10:52 PM
if you read my piece above about the change over to an inline pump, it was on an 87 wagon. Just pull up the back seat and remove the cover plate and access to the pump is then easy.
captchaos
Mar 15, 2016 12:18 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
220k+ A32
Sep 23, 2015 03:38 PM
dcam0326
Sep 7, 2015 07:26 AM
