Mixture Ratio?
Old Jul 8, 2004 | 07:09 AM
Drjmaxx88's Avatar
Mixture Ratio?
I was wondering has anyone messed with the BCDD on there cars?
Does that control the mixture ratio?
I got this info of the Haynes!!!!
Old Jul 8, 2004 | 11:19 AM
maximase86's Avatar
I love lamp.
The BCDD doesn't control the A/F ratio. It prevents the car from going super rich when you let off the gas pedal.
S
Old Jul 8, 2004 | 11:51 AM
Drjmaxx88's Avatar
How do you control Mixture ratio?
Please don't say FICD!!!
Or the Idle adjustment screw.
My car is more than 5% rich according to the ECU.
Old Jul 8, 2004 | 12:04 PM
maximase86's Avatar
I love lamp.
Uhh...with the MAF, and O2 sensor. The kicker is some 2nd gen's had an adjustable MAF....some didn't....
S
Old Jul 9, 2004 | 07:04 AM
Drjmaxx88's Avatar
You think If I got my hands on one of those it would still work for my car?
Im thinking of just taking out the O2 sensor and cleaning it. Adjusting the idle,and fixing all leaks in the intake air tube,getting a new gasket for the Throttle body.
My car had a relapse a week ago with the darkness. So I think the spark plugs might need to be cleaned too. I guess I can do all this when I change the belts this weekend.
Old Jul 9, 2004 | 12:38 PM
maximase86's Avatar
I love lamp.
Man....your car has issues man...
S
Old Jul 9, 2004 | 03:14 PM
Drjmaxx88's Avatar
It was no big deal. Just a relapse of the TPS. The harness jiggled free. Thats all.
The other stuff is maintenance.
Old Jul 9, 2004 | 06:46 PM
maximase86's Avatar
I love lamp.
lol...well you better get your car up to par man. Can't turbo a motor when it's doing crazy stuff!
S
Old Jul 9, 2004 | 09:52 PM
Niku-Sama's Avatar
i found a few good parts cars here. an 85 wagon and a 87 non-floater sedan. mabe one will have a adjustable maf
they have all the parts but some of the parts are inside the trunk
my car is running rich, i had adjusted it and the timing to a bad O2 and replaced the O2 but havent set everything back yet so its being funny...
of course my car doesent blow big huge black plumes of smoke that cause carbon deposits on my paint either
edit:
are there just little screwes on the adjustable MAF
Old Jul 10, 2004 | 07:39 AM
arsonist63086's Avatar
the inrichment screw should be ther, on some maf meterrs the screw is covered up by a littel plate just pop that off and it should be ther, and no the screw isn't small its it like the size of a 10mm screw but you use a flat head to ajust it.
another thing i dont recomand cleaning out the O2 sensor. cuzz it might be good and by cleaning it u might contaminate it and kill the O2. it better just geting a new 1.
Old Jul 10, 2004 | 07:54 AM
try giveing the car a comeplite mantness job ajusting and checking evrything. and maybe your injectors arnt working right thats y its runing rich *** hell.
and r u burning oil?
Old Jul 21, 2004 | 08:39 AM
Drjmaxx88's Avatar
No oil burning
Im burning power sterring fluid.
I think when I ran rich for so long that I killed the catilytic converter. I don't want to replace it but I might have too. Everything on the engine is good. I just haven't been able to hit the sweet spot and get up to optimal running. It may be because the car is 17 years old.
I want to get a 88 Z31 ECU,injectors, and maybe the maf. Then see how better the car feels from there.
Old Jul 21, 2004 | 06:34 PM
Niku-Sama's Avatar
how do you burn power steering fluid?
Old Jul 21, 2004 | 07:59 PM
maximase86's Avatar
I love lamp.
From it leaking/spraying on the exhaust manifolds.
S
Old Jul 21, 2004 | 09:04 PM
Drjmaxx88's Avatar
I adjusted it again tonight hopefully it runs a little better, and warms up quicker.
Old Jul 22, 2004 | 12:58 PM
Drjmaxx88's Avatar
13 min.
It takes that to warm up.
I was trying to adjust it in park but it wont work. I did it in drive and I hope this gets it to ten minutes. Another thing I knew that I needed motor mounts but dang! When I reved the engine the whole motor looked like it was going to jump out of my car. I need mounts bad!
Old Jul 22, 2004 | 07:25 PM
maximase86's Avatar
I love lamp.
How bad? On the auto's there will be a little bit of crawl for sure....but if it's moving like say 4", then that is pretty bad. When mine was bad, that how far I could get it to move. Now with new mounts, the motor will only move maybe a .5". You might consider filling your mounts with polyurethane though....a much cheaper alternative to shelling out the money for new ones.
S
Old Jul 23, 2004 | 08:02 AM
Drjmaxx88's Avatar
Yeah 4" its about that.
I think I may have to do that poly-urethane thing. How long does it take to dry?
Also I was talking to tech support for JWT. Asking about the Cobra MAF,and ecu's,injectors. The guy basically told me to max out my stock injectors and then call JWT.
So ive been batting around the Idea of a CAI box. Just boxing off the where the regular air filter connects to the wheel wail. Aluminum tubing from throttle to the maf to the box with a cone filter.
Why didn't you go for that Maximase86? Seems like it would be a little less problematic.
Old Jul 23, 2004 | 09:35 AM
S
i whant to do the polyurethane thing to cuz the moter moutnts dont come cheap, and i have prevasly replaced all my moter mounts to. so wear can i find some of that polyurethane stuff at?
Old Jul 23, 2004 | 03:04 PM
maximase86's Avatar
I love lamp.
Probably your local hardware store. There is a link in the 2nd gen yahoo groups on how to do them. Just click on the link in my sig.
S
Old Jul 23, 2004 | 06:19 PM
S
can just give me the link to that specific topic cuzz i cant find it
Old Jul 23, 2004 | 07:03 PM
maximase86's Avatar
I love lamp.
Here you go:
http://www.geocities.com/CapeCanaver...-r/mounts.html
S
Old Jul 24, 2004 | 11:16 PM
thanks maximase
Old Jul 24, 2004 | 11:24 PM
maximase86's Avatar
I love lamp.
np, and my name is Sarin btw, feel free to call me that.
S
Old Jul 26, 2004 | 02:43 PM
Drjmaxx88's Avatar
Just got the O2 from nissan dealer. Now I was thinking since the car won't warm all the way up anymore that the air regulator is bad. I guess I'll try that fix from the stickies.
No more after this. If the car doesn't run after this I don't know what ill do with it. Cant turbo charge a hooptie!
Old Jul 26, 2004 | 11:41 PM
maximase86's Avatar
I love lamp.
Though your AAV could be bad....I find it hard to believe that a bad AAV would cause your car to not warm up completely. When you say it won't warm up all the way, are you saying you could drive the car for a few hours and it shows as still being on the cold side?
S
Old Jul 27, 2004 | 08:19 AM
Drjmaxx88's Avatar
Exactly
I was cruisin around 90mph for about an hour on monday. Then I did some drifting in a huge empty parking lot. The car still read on the cold side. Not all the way cold about a quarter of the way to the right.
I know its not the coolant temp sensor, because my car was running a little hot about three days ago and I added coolant. I think I may just drain a little coolant out till I can get the part out or get a new one.
Old Jul 27, 2004 | 08:32 AM
maximase86's Avatar
I love lamp.
Something like that makes me think of a thermostat stuck open. I know of a few guys who's 2nd gen always read on the cold side. As long as it is between the 2 inner most marks on the gauge, that should be considered "normal" temperature range. You said though you added coolant. With a stuck open thermostat, you could theoretically run on the hot side, then adding coolant to the normal level put it on the cold side. You might try pulling yours out and testing it. Just put it in a pot of boiling water and see if it opens or not. You might want to inspect to see if it's open already...it should be pretty easy to tell.
S
Old Jul 27, 2004 | 08:40 AM
Drjmaxx88's Avatar
Sounds good man.
I don't think its the problem,but it never hurts to check.
It was reading hot for five days then three days ago I added the coolant and it hasn't done that since. It won't. Thats the part that scares me. I drove the hell out of my car, and the temp stayed the same. Maybe your right man. Good call!
Old Jul 27, 2004 | 08:53 AM
maximase86's Avatar
I love lamp.
It's a place to start....or you were seriously low on coolant. :P
S
vybz05
Dec 10, 2015 07:38 PM
msellas
Sep 23, 2015 09:16 PM
Serotta33
Sep 17, 2015 12:14 PM
AT978
Sep 6, 2015 10:31 PM
