Seafoam lots of smoke under front..
Old Sep 8, 2004 | 05:58 PM
TwoToneMax
Hey, I'm new to the forum and this past weekend I did the seafoam in the brake booster line thing. I got major smoke from what i'm guessing is the front exhaust manifold. This means a leak right? but it doesn't sound like i have an exhaust leak at all(meaning no vrmm vrmmwhen I accelerate). Any ideas ? thanks ahead of time, The car has 158000 and runs like a top (after a brake job this weekend) Out of curiosity what type of engine oil/filter antifreeze are you guys running. I searched the threads but couldn't find anything. ohh and where do you guys get the shifter bushing from dealer?
Old Sep 8, 2004 | 07:08 PM
blackmaxima88's Avatar
Welcome to the forum.
I actually think that's supposed to happen, because on the can it says something about fumes being extreme for a short time. I tried this on both my vehicles (1994 Sentra and 1986 S-10 Blazer) and it happened with both of those, for about 5-10 minutes, then it cleared up. I guess it depends on how much you dump in there, cos essentially all that seafoam goes to where there's supposed to be air, the intake manifold and everything, and it's trying to burn that. I'd start it up, let it idle, race the engine a few times, and see what happens after 10 minutes or so.
Good luck.
Dan
Old Sep 8, 2004 | 07:35 PM
maximase86's Avatar
I love lamp.
Castrol GTX, 10w-30, Wix oil filter, and 50/50 Prestone.
As for the smoke, Dan is right....unless you notice a "tat tat tat" type of noise when acclerating.
S
Old Sep 8, 2004 | 09:03 PM
Niku-Sama's Avatar
10-30 Valvolene SynPower, Grippy fram, 50/50 of what ever work buys
Old Sep 9, 2004 | 03:13 AM
ASHURA's Avatar
mobil1 10w30, wix oil filter, cheapest coolant out there, self mix to 50/50 (always got an empty 1 gallon jug lying around in the house).
as for shifter bushing..what variety are you looking for?
Old Sep 9, 2004 | 06:03 AM
cardana24's Avatar
Blown
welcome to the board
....mine did the same thing when I sea foamed it...but I dont think I have an exhaust leak.
Castrol GTX 10-30, Fram sure grip, and Prestone 50/50.
--on my fourth gen I use the napa gold oil filter....which you guys using wix may want to look into because you may save a few bux, because napa filters are made by wix
Old Sep 9, 2004 | 02:03 PM
maximase86's Avatar
I love lamp.
Interesting....I'll have to look into that.
S
Old Sep 9, 2004 | 11:46 PM
ASHURA's Avatar
well, by Wix, I meant Napa Gold, because it's basically the same filter, sorry for the confusion.
Old Sep 10, 2004 | 02:59 PM
Jeff92se's Avatar
I'm needing a caw
Napa gold filters are expensive!
Old Sep 10, 2004 | 07:25 PM
ASHURA's Avatar
no they're not..
Old Sep 10, 2004 | 07:56 PM
TwoToneMax
By shifter bushing i mean the oem, I have to nudge it into each gear. Meaning if you would put in in D I have to pull back a little bit before it engages. Another quick question was there a recall for the fuel rail or injectors? just curious if so is there a website I can check if my car was done or not? thanks
Old Sep 10, 2004 | 10:44 PM
ASHURA's Avatar
ah, in that case i don't think it's the shifter bushings, more to adjusting the gear selector cable.
Old Sep 11, 2004 | 03:21 AM
Y3k-Bug's Avatar
Sounds like the shifter bushing to me. They tend to go out on the 2nd gen autos quite a bit, along with the engine/tranny mounts (both of which is true for me).
To my understanding there was a recall on the fuel injectors although it's not coming to me. I'll be looking into finding out what it is shortly, as my mpg has been awful since I bought the car in June and I suspect that the injectors are dirty and need to be professionally cleaned.
mclasser
22
Nov 12, 2020 01:58 PM
BobTX10
Oct 7, 2015 08:43 AM
bernyp
Oct 2, 2015 10:10 AM
