Nissan Maxima 87 clutch separated from air compressor
Hi guys,
I got Nissan Maxima 87, sedan. My air condition went off a month ago. Each time I press the button to turn on the air i would see the clutch trying to engage into the compressor then after couple of squeaks it wont turn and seem just stuck.
I figured that there's no freon left or maybe clutch broke and have not used AC. Now, a month later I started hearing a rubbing noise while driving. I looked and saw that its coming from air compressor. I moved that clutch a little and it stopped. Next thing I started hearing banging noise while driving, I discovered that the clutch just separated from the compressor and now hanging between compressor and body frame of the car.
I tried to push it and succeeded, but it will fall out again...
What to do? What caused it to come off? In the book i have not found any info on the part. Do i have to go to the junk yard and try to get whole compressor? This thing wont stay in the compressor. What would you advise to do to fix this?
Hmmm, I'd say going to a junkyard and pulling a compressor is the easiest route....but you have to make sure the compressor is in good shape. I've never had that problem with the a/c clutch, so I'm unsure if your situation is repairable or not. You might be able just to grab a clutch and replace it....but someone how I got a feeling that won't do.
S
S
I have a 87 automatic, and My A.C. compressor just froze up on me the other day while driving, and Now I can here a rubbing sound when at idle comming from the compressor, And it will stall the engine if I dont keep the idle up high enough. Is there a way to lube the compressor or does it need replacing?
I dont think the compressor can be lubed or anything...
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
julian888
Aug 6, 2015 04:39 AM
