88 max aod help
Old Nov 30, 2004 | 05:36 AM
roc87's Avatar
88 max aod help
88 max aod,has anyone been able to get around the issue of not going into overdrive until the car reaches a certain temp?i enjoy the max,but its rough on fuel.is there anyway to get around this issue,if i let it idle,it cools down on the interstate and then jumps out of o.d to warm back up.thanx
Old Nov 30, 2004 | 09:14 AM
wylie-c's Avatar
It's not really an "issue" with these tranny's, but that is the way Nissan designed them. Something about preventing OD from engaging below a certain temperature to prevent damage to the tranny, so I feel it's best left that way. In cold weather mine kicks in and out of OD on the highway, but I've gotten used to it. You could always just block a portion of the rad with cardboard if it really bothers you, then it would stay runing a bit warmer at idle though.
Old Nov 30, 2004 | 09:22 AM
cardana24's Avatar
Blown
I was also going to recomend some cardboard over the radiator to keep it hotter.....or you could put a hotter thermostat in (if its even available...but I would NEVER recomend doing this)
Old Nov 30, 2004 | 10:13 AM
turboast4's Avatar
The OE thermostat on our (2nd gen) cars opens at 170F, I believe. Usually parts stores offer two different temps, with the hotter ones being like 195. In the winter it's ok, cuz you'll get heat sooner from a colder engine, but like cardana said in summer it'll probably be bad. I suppose you could add more water to the coolant mixture as well.
Old Nov 30, 2004 | 12:13 PM
roc87's Avatar
hey guys,thanx again for the quick feedback.guess i'll have to get used to it.a five speed sure would be nice.thanx again
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
