talking lady voice box
Old Jan 7, 2005 | 10:32 AM
bagpipeswest
I think my voice box on my max died. Does any one have one.
Cheers
Brent
Old Jan 7, 2005 | 12:17 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
2 words: JUNK YARD or one more: DEALER
Old Jan 7, 2005 | 10:02 PM
007max's Avatar
is it only the 1st gen maximas that had maxine?
Old Jan 8, 2005 | 06:36 AM
belakithom's Avatar
Lol, No. The second generation also. It was disocntinued when the totally revamped third generation was introduced in 1989
Old Jan 8, 2005 | 06:03 PM
007max's Avatar
so my '88 has like every option including digital dash and dual power seats... should it also have maxine?
how would you know that you have the voicebox installed if it doesn't work?
Old Jan 8, 2005 | 06:47 PM
Niku-Sama's Avatar
OK little trivia thing here
Floater cars do not have the voice box nor will they have adjustable suspension (atleast 80% of them dont because they are floaters, 20% because they didnt want the option)
Reason:
People in Panama or where ever they were going to DONT SPEAK ENGLISH, and the suspension is because the roads were to bumpt or the cold or hot screwed it up or something i cant rember, there was something else about the antenna too but i cant rember it.
i'm pretty sure mines a floater but i dont mind not having the adjustable suspension because it would just break on me any way.
Old Jan 9, 2005 | 06:23 AM
wylie-c's Avatar
I don't know about 87-88's but in mine the box lives under the center console. If you pull out the bin that's under the ashtray, you'll find it.
Old Jan 9, 2005 | 07:34 AM
bagpipeswest
On my 83 it is just above my left foot. The box is about 4''x4''x4''. Inside it has a little white record. A relay drops the needle on the record. On mine the relay does not stay down.
Old Jan 10, 2005 | 04:29 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
does anyone kno if you can change the voice on the record to say more vulgar or funnire things such as "keys in the ignition" to "get your keys byiotch" or "right door is open" to "close my door you a$$"?? just wondering.
Old Jan 10, 2005 | 05:02 PM
jos's Avatar
jos
My 87 that i am parting out still talks. if in fact the box and hook up is the same for your max as someone above suggested send me an email at jsluszka@yahoo.com. I can check mine if you want to check yours.
Old Jan 10, 2005 | 05:43 PM
007max's Avatar
Originally Posted by Big_E-Dog
does anyone kno if you can change the voice on the record to say more vulgar or funnier things such as "keys in the ignition" to "get your keys biotch" or "right door is open" to "close the door you a$$"?? just wondering.
i'm sure its possible if you have a little knowledge of electronics. i'm not sure how the thing is wired up stock but the way i would do it (provided it wasn't wired for me already) is run the wires up to the warning lights on the dash such as the low gas and parking brake and then go from there...
its worth a shot if you want to put in the time
Old Jan 10, 2005 | 05:51 PM
turboast4's Avatar
It would rock if someone could record the voice in a high quality format so it would be "preserved" and anyone could fit it their car (maybe even new Max's) without needing the factory box. It might be easier to manipulate the words too.
Old Jan 11, 2005 | 02:34 PM
max'dout06's Avatar
i was just jumpin' around in other forums - and saw this thread...... if i got lucky and found a voice box - how's the wiring, and is it possible to use it for a newer max.
Old Jan 11, 2005 | 03:54 PM
blackmaxima88's Avatar
I'm sure it's possible, but you'll be staring at wiring diagrams for hours. you'll have to find out how the wiring connects, and then wire everything in, then probably connect the output to one of your speakers....
I took the standard instrument panel out of my 86 s-10 blazer, which only had warning lights for oil pressure, coolant temperature, and the alternator, and completely bastardized it and installed an instrument panel from one that had gauges for all that stuff. it meant replacing sending units for the oil pressure and water temperature, cutting and splicing, tracing the wiring for each individual warning light (ever realize how many you have?) and moving wires around on a wiring harness. and then cos GM has to do everything bass-ackwards, there was a separate oil pressure circuit to shut down the fuel pump, and a separate temperature circuit for a "check gauges" warning light I had to wire in. check gauges replaces the oil pressure and coolant temperature warning lights.
moral of the story? any electrical mod is possible, but most are time consuming. my next one is to upgrade the instrument panel in my sentra to one that has a tachometer. this oughta be fun.
Dan
Old Jan 11, 2005 | 05:59 PM
max'dout06's Avatar
thanks a lot!!!
Old Jan 16, 2005 | 06:35 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
i checked out the voice box opened it and saw what was in it it was surprising i thought i would find a tape recprder or different chips that said different things but there isint there is a big chip and a lot of colored resistors there i wonder how i would feed the recording into the chip like someone said it will be a task, a task indeed!
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
Stagnet04
Sep 14, 2015 11:28 PM
coasterswim
Sep 2, 2015 07:43 AM
