my car is idling at 4,000 RPMMMMMMMMM
Jun 27, 2005 | 01:55 PM
well today i was changing the oil and i noticed that the air regulator wasent hooked up (the connector is ****ty) then i was done with oil and about to back down from ramps but the car was idleing at 4,000 sounding like it was about to blow up (i dont get it because it was running ok with the airrgulator unplugged) so then i rembered when i was changing oil filters that there was a wire in the way and it might of got messed up (its a pain to get oil filter out, till today i found a fairly easy way) but the thing is some kinda sensor with a wire that plugs up onm the firewall, i looked at the air regulator rebuild.
i dont know what to do now i dont even knwo what that sensor thing was
im sorry for this jumbled up mess
Jun 27, 2005 | 03:24 PM
Hey
What temp is your car at when it Idles like this?
Have you advanced your timing at all?
Is your air regulator hooked up when it idles at 4000, what does it Idle at when you disconnect it?
Jun 27, 2005 | 05:45 PM
i tryed it at cold and hot temp
no didnt mess with timing
air regulartor can be hooked up or not its the same
i think when i hooked it up it opened and now it wont close??
how could i get it closed, or should i try to get a working unit??
Jun 28, 2005 | 06:02 AM
I had this same problem after changing oil. It was because I cange my oil filter from the passenger side of the car, I leaned on the throttle cable going into that black plastic thing on the fire wall, the cable got hung up on that thing, just push the cable back toward the fire wall....I am willing to bet this will fix your problem, good luck
Jun 28, 2005 | 06:12 AM
Agredd, the air regulator shouldn't cause you idle higher that maybe 1500RPM...it's not going to make the car idle faster than it normally would...
Jun 28, 2005 | 07:19 AM
yep it was the throttle cable, its such a fen pain to get the oil filter out, i musta got it pulled out somehow,
thanks for all the help
Jun 28, 2005 | 07:32 AM
Quote: yep it was the throttle cable, its such a fen pain to get the oil filter out, i musta got it pulled out somehow,
more pics of girlfriend for solving your problem?
I see in your sig you are from Burlington, I think I have been to your high school for a football game. Do you guys usualy play the Clinton Dark Horses in the state tournment?
Jun 28, 2005 | 08:44 AM
went to the yard of junk
i went to the junkyard today i got a air regulator the hose the little gasket (which i was missing) and the plug, i also seen a (floater) radio plastic thing, which i will hope to get my radio looking right, but i dont know how the equalizer and clock will work out. i got it all for $10
idk if we played you, i go to Williams
