Dec 17, 2005 | 10:36 PM
  #41
oh....i am guessing there are more 300Z related parts on it considering its configuration...
i know in japan cedrics and glorias are turboed aswell could be another reason
Dec 18, 2005 | 07:39 AM
  #42
Yea the 300zx should work on the 300C the engine bay harness looks the same and the distrebuter is the same one as a 300zx or max.
the only ting that might be diff. is the harness that goes plugged in to the ecu, witch can be wierd up to plug into a 300zx or max. Ecu.
All you have to do if it doesn’t fit is cut the 300C's ecu plug and wier up the 300zx or max. Ecu plug.
In order to do that you will need to have a molty meter (must know how to use a moltiy meter) the 300zx or max. Ecu wiring diagram (must know how to read a wiring diagram)
i have the wiering dieagram for a 1985-1986 max, ill try to scan it and post it (if i can figer out how to post a pic )
Dec 18, 2005 | 08:14 AM
  #43
as for performans diffrences with puting A 300zx ecu in a max is noticabel.
in my max. (hope shes in goog hends ) i noticed better throtel respons, amother idel, increas in redline better fuel econamy and more *****.
the mods i had in her (max) prier to installing the 300zx ecu wer a C.A.I, a bored out intake manifuld to fit in the 240sx t.b. cleaned out the intake maifold, 20-50w oil, on the dot ignition timing, and runing 87 pump gas.
i would swap back and forth between max. and zx ecu's to check cheanges. with he max ecu the idel was rufer then withe the zx ecu. and no i didnot rewier anything just pluged it in
Dec 18, 2005 | 08:18 AM
  #44
Quote: Yea the 300zx should work on the 300C the engine bay harness looks the same and the distrebuter is the same one as a 300zx or max.
i forgot the only thing that i see diff is that ters no air ragulator.
Dec 18, 2005 | 10:22 AM
  #45
Quote: i forgot the only thing that i see diff is that ters no air ragulator.
its there, its under some other junk, you can see the connector under the PCV hose
Dec 18, 2005 | 10:52 AM
  #46
oh i see it the it should all be ok then
Dec 24, 2005 | 03:43 PM
  #47
ok i'll try this again...
where in the factory service manual does it tell you how to re-calibrate for a MAF?
Jan 7, 2006 | 03:57 PM
  #48
Thank you for the information.I replaced the ignition coil and the power transistor. I used the part numbers of Z31 300ZX parts to order the parts, and they were compatible. I still don't get spark. The previous owner had cut the capacitor and resistor away with the connectors. The parts were on the front seat. I don't know why he removed the connectors too, because it is easy to just remove both components from the connectors. I think I should replace the wiring harness between the power transistor and distributor. I hope he hadn't tried to connect the wires without resistor.
I took the information to draw this from the original wiring diagram. I forgot to draw the fusible link to the picture, but there is one before the battery.
Connecting a wire over the resistor would let high current flow directly to ECCS unit and I don't know if it can take it. Obviously the car can't run without the capacitor. My 300ZX ECCS I bought from eBay haven't arrived yet. The next thing I am going to do to check is the sensor in distributor.
I have a distributor from 1989-1993 Maxima. Any idea if it works in 1st generation Maxima or Z31 300ZX?
Jan 7, 2006 | 06:12 PM
  #49
it should since its still a vg30e
Jan 8, 2006 | 04:03 PM
  #50
Quote: it should since its still a vg30e
Any idea if the early Maxima wiring harness is compatible with this one? I am asking the same thing again because the car is 300 miles away.
Here are some pics of the distributor. cap is different and I don't remember how the Y30 / Z31 connector looks like.
Jan 25, 2006 | 06:52 PM
  #51
Doing this in a few days/weeks , The hard part sofar is finding the Freaking junk yard that has it.. Sofar 1 dident have it.. any help her in finding the ecu , and maf , For a 88 auto?
Jan 28, 2006 | 08:00 PM
  #52
y dont you just chang the distributor fo a max or z31 dis?
Jan 28, 2006 | 08:26 PM
  #53
Quote: y dont you just chang the distributor fo a max or z31 dis?
same dang thing just certain things are different like heads ecu maf, or at least i think its the same....
