coolant + timing belt
Old Sep 3, 2005 | 09:06 PM
Niku-Sama's Avatar
ok i am just curious, does coolant decreace the life span of a timing belt?
and if so how much?
i have a leak and i think it was something that wasnt installed correctly.
Old Sep 4, 2005 | 06:22 AM
wylie-c's Avatar
I have heard that a coolant leak will compromise the timing belt. What happened? Is your water pump leaking?
Old Sep 4, 2005 | 11:57 AM
Niku-Sama's Avatar
yes.....again, i dont know what the deal is, i had it replaced when the timing belt broke before....
i check for moisture on the other belts hoping its them but i dont see any thing and they are all tight and i am losing coolant pretty quickly (1 res fill per 2 days) i do get drips but when the res isnt full i dont get drips (mabe already too low) and i can check the thermostat housing and from what i can tell it isnt leaking so that only leaves 1 last thing.
Old Sep 4, 2005 | 06:15 PM
maximase86's Avatar
I love lamp.
You sure it's leaking there? Do you see coolant on the ground? Could be a bad head gasket. Check the oil for milkshake at all?
S
Old Sep 5, 2005 | 12:36 PM
Niku-Sama's Avatar
nothings mixin and i am not getting excessive moisture out of my exhaust
Old Sep 5, 2005 | 12:43 PM
Matt93SE's Avatar
STFU n00b!
pull the timing covers off and look for the leak. if you have antifreeze leaking on the belt, is WILL eat it up and it will fail fairly quickly. not a good idea if you don't want to replace the engine.
Old Sep 5, 2005 | 09:13 PM
Niku-Sama's Avatar
the timing belt is just over a year old as is the pump, aparently the pump (if it is indeed the pump) is defective, and it hasnt been leaking long so combined with the new-mess of the belt i dont expect it to fail before i get arround to replacing the pump...if it is indeed the pump (because i dont know 100% untill i pop the timing cover off) if its leaking now it could let out all at once so i am constantly watching...
but i need to fix a few things before and get paid first before i can go into the car like that and put it out for a week
i have also been looking for a new job and i've been mucho busy but if i get a better paying job it'll certianly help
tsi6001
Oct 3, 2022 10:23 PM
Jcof88
Sep 9, 2015 03:11 PM
FlaMark
Aug 20, 2015 12:17 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
