Car slows down and speeds up.
Old Jun 2, 2001 | 03:00 PM
jose6220
My 1987 Maxima would be running normal then it slows down then pick back up speed. It would also jerk when its slowing down. What could be wrong? I would really appreciate you help.
Thanks in advance
Joseph
Old Jun 9, 2001 | 07:01 PM
Engloid86T
Thanks in advance
Joseph
Two things that could be causing this:
1) if it does this at idle, then you need to clean the contacts to your cylinder head temp sensor.
2) if it does it while driving, you should adjust your throttle position switch.
Engloid86T
Thanks in advance
Joseph
Old Jun 9, 2001 | 07:21 PM
jose6220
It does it when I'm driving. How do I adjust the throttle position switch? Where is it. Do you think I can fix this or I should carry it to a shop. I don't know much about cars.
Thanks for you help
Joseph
Old Jun 9, 2001 | 07:27 PM
Engloid86T
Thanks for you help
Joseph
ON the side of the throttle body is a small black box. It has a wiring harness connected to it. THere's two small screws that hold it. loosen them just a bit. Start the car and let it warm up. You'll need something to check continuity...
WHen warm, pull the harness off. Roll the sensor down (end with harness hookup). PUt your meter to the top two terminals inside the switch. Have a buddy hold the idle at 200-300 rpm over idle speed. Roll the sensor back up slowly till you get continuity between the top two terminals. Tighten the screws and you're done. Haynes manuals should tell how to do this also.
If you take it to a shop and they want you to buy a new switch, they're probably idiots and wouldn't know how to set the new one if you bought it for them, and your problem would still exist.
Lakersallday24
Jun 16, 2019 01:35 AM
schmellyfart
Sep 25, 2015 04:47 PM
RealityCheck
Aug 5, 2015 06:18 AM
yat70458
Aug 3, 2015 01:16 PM
