Fuel pump ordeal, need help.
Old Nov 21, 2005 | 11:16 AM
PringleSoldier's Avatar
Hi guys,
I started having problems with my fuel pump. Long story short, because I need to go to work, when the temperature drops the fuel pump will stop working. However, if I pour a bottle of HEET inside the fuel tank, and try to crank the engine, it starts and I can hear the pump engaging.(condensation around fuel pump?) It's driving me insane, I get the best fuel out there (87) with no water in the fuel, and even if there was, I always put a bottle of techron every fill up.
So I need to by a new fuel pump. This can't go on, it's going to get extremely cold here Texas and my Maxima is not prepared. I checked with the dealers, and the fuel pump for my car is $400!
I can't afford to dish out $400 at the moment, I checked at partsamillion.com and they have the bosch "fuel pump only" for $136.70. Does the pump come with something else? I also found this site:
http://www.fuel-pumps.net/fuel-pumps...-0l--sohc.html
The walbro fuel pumps. Sarin was talking about them once.
So, my main question is, will a fuel pump for a 1989 maxima work for an 87?
Also, I know there are a few members that have had fuel pump problems before, where did you purchase your new pumps and would you all please drop me some links for me to look at after I come back from work?
Thanks guys, let me what you all think.
- Best Regards,
- David Steele
- Take Care
Old Nov 21, 2005 | 11:52 AM
Niku-Sama's Avatar
the only thing i can think of is lay off the additives so much, every once in a while is good but every time can cause problems
Old Nov 21, 2005 | 03:21 PM
jos's Avatar
jos
Pull your back seat and check the wiring at the pump. Cold shrinks metal. Maybe a bad connection. Also check the relay.
Old Nov 21, 2005 | 05:26 PM
I thought about doing this, but the need to pull back the seat was what put it off since I won't be putting anything new in. Nevertheless, I will check. Where's the fuel pump relay? Also, this was happening before the additives, which claim they are safe when you pour them at every fill up. However, I'll stop for the time being, I want FP60 and that's what I'll be ordering.
I still believe I need a new pump, I can't risk getting stranded, doesn't any have any links or suggestions regarding fuel pumps?
- Best Regards,
- David Steele
- Take Care
Old Nov 22, 2005 | 12:08 PM
No one knows anything about the fuel pumps I mentioned? Anyone with any information please post, I'm still having issues with the pump.
- Best Regards,
- David Steele
- Take Care
Old Nov 22, 2005 | 04:59 PM
max95q's Avatar
Im not sure if they will work with an 87. Ther eis always trial and error to see if it will. I would also like to see because walbro only makes fuel pumps for the 3rd gens and up. And if it does work then I will be ordering a walbro. I havent had much time to do that though, plus there is nothing wrong with my fuel pump...yet anyway.
Old Nov 22, 2005 | 06:41 PM
Niku-Sama's Avatar
isnt there a seperate regulator in the line?
Old Nov 22, 2005 | 10:53 PM
VideoMan's Avatar
You can give this web-site a try for used fuel pumps:
www.car-part.com
They had some fuel pumps listed between $40 and $90 in the Texas area.
Old Nov 23, 2005 | 05:10 AM
max95q's Avatar
I have a pull a parts place about 30 miles from me so Ill probably go there. Even start looking for that 87 300zx MAF and ECU. Those cars are hard to find in junkyards.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
