1984 nissan Maxima with fuel injection
Old Jun 4, 2001 | 02:03 AM
mac16666
my maxima will start and idle, but it wont accelerate. It stalls when I try. Ive checked the fuel pump, the fuel filter, and the pressure regulator. Ive also checked the vacuume lines.I need to get to the ECU,I saw a site that said you could get into the panel that houses the ECU by going through a place next to the accelerator peddle(?),My email is wer7now@juno.com I really need to get this car running and any info would be greatly appreciated.
MAC
Old Jun 8, 2001 | 10:35 AM
indy_84maxima's Avatar
I have listed 84 ECM part numbers in a previous post. The ECM is located under the passenger's seat.
Old Jun 10, 2001 | 08:05 AM
chad_e0's Avatar
When you replaced the fuel pump, did you disconnect the battery? If you did not do that, I would disconnect the battery. Leave it disconnected for about ten minutes. This will re-set the computer. The computer may be confused. I had a simular problem after changing the timing belt. Just a thought.
Chad
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
