problem with stanza tb
Alright i got every thing hooked up , Now when i press the gas when im driving it just drives normal , Like im not pressing the gas in all the way.. no matter how far i press it , It goes up the same , it takes me like 15 secs to get to 60 , Useally it takes me 7-8 , When i do a 0 to what ever Like for the first 10 mph , It car has good acceleration , Then all of the sudden i just loose like more then 50 % of my power...
dtm88na says i may have to transfer linkages , Since its almost the same thing as this tutorial for getting a 60mm tb from the 240zx and putting it on the 300zx as it says on this page.
http://www.thumper300zx.com/
Then click modifactions then click KA24(e) (240SX) Throttle Body Modification
then go down and click For the full explanation click here
Then go down to where it "Once you have the inlet/outlets facing backward" then read on from there .
Originally Posted by DJ Technischer
yeah itsdelayed plus it wont give me any power , Unless im like between 1000k-2000k rpms , After those it just drops back down and drives like i am only holding half of the gas in .
You mean the thing connected onto the tb the little electronic ? Its like a little black box on the right of the tb ? How would i adjust that?
You need to use an ohmeter to properly adjust the TPS. Refer to this link for the details.http://z31.com/repairs/tps.shtml
Cardana's method will work if you don't have an ohmeter, but you really need to use one to do it correctly.
litch
123
01-04-2024 07:01 PM
HerpDerp1919
09-29-2015 02:02 PM
