My intake...
Old Feb 18, 2006 | 10:36 PM
DJ Technischer's Avatar
My intake...
Alright i fineally got every thing hooked up , took me hours since , It was so could and had to use a blow dryer on every thing , but after like 5 seconds it will stall out , And if you rev it , Right after the revs hit 1k the engine shuts off..
Heres the setup I put a breather filter on the cam cover , And one Up neat the erg .
What do you think the problem is here?
Old Feb 18, 2006 | 10:58 PM
Niku-Sama's Avatar
i think problem #1 is a real MAF adaptor with bolts instead of mysterous red goo holding it together, make sure theres a round rubber gasket on the flange side of the MAF.
hook that hose with the little cone filter back to to the rest of the car, i think (not positive) it needs to draw from the intake AFTER the MAF.
hook that other hose on the valve cover up the the rest of that intake before the MAF and the garden hose i think also needs to be hooked up after the MAF and also...garden hose!?!?!?
i am not 100% on all of these its 11:00pm i'll check my car tommorow
Old Feb 19, 2006 | 07:46 AM
any other suggestions?
Old Feb 19, 2006 | 09:14 AM
Nvm it was just the garden hose.
Old Feb 19, 2006 | 09:26 AM
but the Cupluars are pos , and the clamps that come with them SUCK They turn into plastic , And the hardly hold , So im just going to do the intake the Ghetto way.
Old Feb 19, 2006 | 10:17 AM
maximase86's Avatar
I love lamp.
Your problem is you pulling vaccum before the MAF. The blue hose you have going before the MAF needs to do after the MAF. Next your MAF is on backwards. The arrow needs to point to the throttle body. Third, the MAF is too close to the throttlebody, so when it shuts is causes some oscillation in the air.
So all in all, your install is bad.
S
Old Feb 19, 2006 | 12:06 PM
But is it ok to have a breather filter on the cam cover?
Old Feb 19, 2006 | 01:09 PM
max95q's Avatar
How was it the garden hose?
Old Feb 19, 2006 | 01:29 PM
maximase86's Avatar
I love lamp.
You can't have anything connected circled in red here if comes from the intake manifold. Since you have one port, the AIV can be connected here. If you have connect something other than that there, unmetered air gets into the motor and causes it to stall.
Circled in yellow is the MAF. There is an airflow arrow. It must point the in the direction of the throttle body or it won't work properly.
S
Old Feb 19, 2006 | 04:00 PM
I did every thing right this time , Now it wouldent Go above 2 k Rpms ... And when it was backwards it did , Ohh well ill just do a diffrent set up , Ill post pictures when im done tonight.
Old Feb 19, 2006 | 04:01 PM
once it got really cold i couldent tighten the Clamps to connect it to the tubing , And it was letting air out.
Old Feb 19, 2006 | 04:42 PM
Alright Heres what the final product looks like.
works like a charm , i can very much tell it gave me an increase .
Old Feb 19, 2006 | 08:30 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
well look if you want to delete the whole air box thingy toull need to plug everything after the maff except for the hose you put the lil cone filter on attach the maf to the filter with the direction arrow that says flow on it towards the tb and make your custom connection from the maf to the throttlebody there there should be about 4 connections betwen the tb and the maf not including the crankcase hose or tghe one you put a lil filter on..... hope this helps..
Old Feb 20, 2006 | 06:06 AM
cardana24's Avatar
Blown
glad you got it in. Sarin said what I was going to say.
Old Feb 20, 2006 | 06:08 AM
max95q's Avatar
DJ go to my Cardomain site. I have pics of what mine looks like there if you need reference.
Old Feb 20, 2006 | 07:33 AM
Ive tryed that set up a couple times ... Maybe it was just The rubber cupplers that turned into plastic in the cold , And the clamps that if you tryed to tighten them , They wouldent just reset back to the Beggining , Thats what i get for buying **** from pep boys...
Old Feb 20, 2006 | 07:27 PM
Niku-Sama's Avatar
ok i have to say your engine compartment was so dirty i felt like i had to wash mine today.
i feel better
Old Feb 21, 2006 | 12:43 AM
Yayomax's Avatar
still brewin'
It really looked like your MAF unit was facing the wrong way in those first few pics. the round part is supposed to be facing the intake manifold and the side with four bolt holes should face the fender. that is where you hook up the adapter for the piping/cone filter. other than that, I love the setup!
BTW everyone, I just picked up a 5th gen last weekend. wish me luck.
Old Feb 21, 2006 | 06:23 AM
Yeah i tried it the right way around still wouldent work , Maybe because i needed to hook up the crankcase hose also to the tubing... Trust me my engine bay is alot cleaner then more the a few people on this site , Ive cleaned it , Its just hard to clean.. Any Suggestions ? I have used Grease lightning ..
Old Feb 21, 2006 | 09:25 AM
E-CARP's Avatar
Breather
Definitly NOT, The pcv system must be a sealed system, If a car is running, (mine) and the oil filler cap is removed, the engine dies because it is leaned out so much! Thats why I'll bet yours won't idle??? Get all the hoses back to their original locations on the car, get rid of the breather filter, and put the MAF on with the arrow facing the throttle body, and it should work!
Good luck, Earl
ALL THAT FOR A PRETTY AIR FILTER???????
Old Feb 21, 2006 | 12:11 PM
Haha , Yeah I mean i know the breather filter on the crank case will work on some cars , Just dident know if it would for ours. do you think since i only have One opening on the intakje tubing , Do you think i could get a t connector and just throw the tube from the Crankcase cover , And the Im cover on there and think it would work then?
Old Feb 21, 2006 | 05:32 PM
dtm88na's Avatar
I was looking at the picture, and I would recommend getting a real gasket for between the TB and the plenum. I can't tell what that is, but it definately isn't right. Just a suggestion.
Old Feb 21, 2006 | 05:58 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
hey dj who is that in your sig???
here is my old setupbefoer the implosion....
Old Feb 21, 2006 | 06:15 PM
E-CARP's Avatar
lets air oit???
DJ, I think you meant let air in, unless I'm not seeing the supercharger in there!
Earl
Old Feb 22, 2006 | 10:35 AM
Yeah i ment out , And every time i would open the TB air would come in thru the Filter and go thru the tubing , And prolly come out some where , But how i got it , Now is cool. Just some times it acts funny.
Old Feb 24, 2006 | 08:52 AM
Its just so annoying every thing you want for performance for these cars , You have to get done custom....
Old Feb 24, 2006 | 09:36 AM
Mr. Blue Sky's Avatar
thats just part of the joy of being a 2nd gen maxima owner
Old Feb 24, 2006 | 11:26 AM
Yeah , We are unique not like a honda when you have to spend like 10k on it just to get it to run 15's...
Old Feb 26, 2006 | 06:13 PM
Hump-Free's Avatar
Nice, I loki it a lot.
happy4444
Dec 16, 2008 05:40 PM
19max95
Jul 1, 2008 09:46 PM
02'maxed-out
Jul 10, 2003 06:50 AM
