1985 SE timing belt questions
Old Jul 14, 2001 | 07:31 AM
AVO3VOM
I have a 1985 Maxima SE with 124,000 miles. I just bought it and got it through inspection, so now I have to start thinking about all the little maintenance items I'll need to square away before I have anough confidence to daily drive it.
Well, having it on a lift was encouraging, other than a busted vacuum line the car seems to be in really good mechanical shape. No leaks from what I can see.
One thing though. The PO said he had never replaced the timing belt, and in the service manual and the owners manual I was not able to locate an interval to change it. Also on this site the service intervals don't list the timing belt.
So does anyone know of an interval to change the timing belt on this thing, and also is it an interference engine?
Brian
Old Jul 14, 2001 | 08:34 AM
Stubie
60000 miles
The recomended interval is 60K, and yes it is an interferance engine.(darn!)
Stubie
Old Jul 14, 2001 | 01:58 PM
AVO3VOM
Re: 60000 miles
Stubie
Then it sounds like I betta get off my butt and do it!!! (or more specifically PAY someone to do it!)
Thanks Stubie!
Old Jul 14, 2001 | 05:39 PM
Nismo87SE's Avatar
while your getting that done.....
Replace the water pump, front crankshaft and camshaft oil seals, thermostat, drive belts at the sametime. This way you won't have any leaks or overheating problems that is difficult to fix. Besides there shouldn't be any extra labor charge to replace all the parts either.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
max_speed97
Aug 26, 2015 07:46 PM
JMag90
Aug 25, 2015 09:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
