84 Maxima has hesitation...
My 1984 Maxima has a hesitation when you start out from a dead stop. It's much worse when you have the A/C on. Now that it's getting colder here where I live, it's a little harder to start in the morning. I took it to the Nissan dealership and they said it was the head temperaure sensor. I replaced it, but it still runs the same. Another thing is that it has terrible gas mileage. Can anyone help me please?
Re: 84 Maxima has hesitation...
The Fuel Pump and Fuel Pressure Regulator are common problem areas with my car. I was experiencing a simular problem. Some yahoo mechanic had crushed my gas lines by misplacing the blocks for the lift. This caused my Fuel Pressure Regulator to wear out prematurely. I still have my original Fuel Pump at 160K miles.
In your case, you need to have access to a Service Manual.
1) Test Fuel Pressure.
2) Using a Voltmeter, run tests on all sensors used by the ECM (Fuel Management Computer). Sorry I don't have the specs.
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
