Speakers
Old Nov 2, 2001 | 06:33 AM
pillage6
Speakers
Just wanted to know if there are any direct replacements for the rear deck speakers? I would like to upgrade them without cutting or having something custom made. Any information would help, thank you!
Old Nov 2, 2001 | 06:20 PM
aztellez's Avatar
I think we had a thread about speakers earlier in the year. Do a search for that.
I just brought some infinity 6x9's in through the bottom of the rear deck. No cutting required, sounds xllent. Are you going to put subs in too? I didn't run subs, but I still wanted bass so that's why I ran the 6x9s.
- Jorge Tellez
Old Nov 3, 2001 | 07:05 PM
maxima561's Avatar
you can use almost any 5.25 speaker and you should not have to cut anything. Hardest part is cutting off factory speaker wire connector
Old Nov 4, 2001 | 06:04 AM
aztellez's Avatar
Yeah the factory connector was a pain
pillage6, I would try my 6x9 setup. And definitley attach your amp to the back of the fold down seat. For some reason it impresses people when they ask "what kinda amp you have?" and you just pull it down and show them.
later,
Jorge
Old Nov 4, 2001 | 09:54 AM
konan's Avatar
Try www.crutchfield.com
I believe you may have an odd size speaker a 4 inch in the rear parcel shelf area. I purchased a pair a while back from crutchfield but returned it b/c after replacing the dried out front door speakers the rear's didn't make much difference.
Old Nov 5, 2001 | 01:43 AM
Psychos's Avatar
I know you don't want to do anything custom, but I installed 5 1/4 in components and cut a bracket out of plywood and wrapped it in black carpet-really easy if you have a jigsaw. that way both cutouts in the rear deck were covered and I got great speaker sound. Trace the outline of the plastic speaker housing and transfer it to the plywood and then place the speaker template and make your pattern. use long bolts and you might have to drill four holes into the rear deck sheetmetal. good luck
Old Nov 7, 2001 | 02:23 PM
SuDZ's Avatar
later,
Jorge
Yeah people are randumbly into stuff like that. Just different I guess.
SuDZ
Mar 12, 2020 12:06 AM
magiconthetire
Oct 26, 2015 09:03 PM
Excalibur23
Oct 13, 2015 04:33 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
