1st & 2nd Gens are fading away.....
Old May 14, 2014 | 09:09 AM
  #161
bdeleon89's Avatar
question
Ok so My 88 Maxima wagon is giving me this weird issue. I have to heat it up before I drive it because if I don't it doesn't want to shift. It is an automatic if it helps. I was thinking maybe it has a tranny filter that is all clogged up or something. I noticed the tranny fluid in it was a little low and it was very watery looking not thick at all. It was hard to see how much thee was in there with the dipstick. Would it be a bad idea to replace that filter (if there is one) and also replace the tranny fluid entirely? I heard its bad is that true? I want to learn as much as I can about this ca. It was a gift and I absolutely love it and want to fix it. ANY SUGGESTIONS?
Old May 14, 2014 | 09:24 AM
  #162
Amerikaner83's Avatar
Well, starting your own thread is the first suggestion.
Second suggestion is to get your trans fluid drained and refilled, and replace the filter (if it's meant to be replaced, some aren't). NO power flush or anything, just a simple drain and refill.
Old May 14, 2014 | 09:43 AM
  #163
bdeleon89's Avatar
I wish I could start it but after this I still have 11 more posts before I can lol. I think I am going to try that. How do I know if the filter is meant to be replaced?
Old May 14, 2014 | 11:42 AM
  #164
lowpost99's Avatar
Sounds like slippage to me.. you either have too little or too much AT fluid in the system.
I'm doing a flush from Valvoline Dex/Mercron III, to full synthetic Mobile 1 fluid in a day or two. Seems to have good reviews and chemically exactly the same as Amsoil at a lot less $$$.
The filter removal is bit tricky, and can be cleaned without removal with brake cleaner.
I've always done any transmission flush on any car just like this....
always check the fluid car on warm, level ground, shift through the gears and then check the stick 3 times wipe each, read the cold side. Then after a 5 minute drive for comparison, rinse and repeat but read the hot side.
Read this post for an overview...
http://forums.maxima.org/fluids-lubr...eck-level.html
Two cautions, Be sure to check the levels for reference or you'll put 10 qts in when you may only need less to fill, and could end up overfilling again. Second be sure to dis-connect the return line at the cooler and run a plastic hose from there, vs the tranny or you'll make a mess when you crank the car and it's spews fluid everywhere! Good Luck!
Old May 16, 2014 | 10:14 AM
  #165
bdeleon89's Avatar
thanks for the tip
Old May 16, 2014 | 03:44 PM
  #166
lowpost99's Avatar
Changed to Mobile 1 today....
thanks for the tip
No problem pretty simple and took about an hour including setup and cleanup.
Old May 21, 2014 | 03:12 PM
  #167
bdeleon89's Avatar
aghh!
uh uh something went wrong. wtf?!
Old May 21, 2014 | 03:14 PM
  #168
bdeleon89's Avatar
what is this?
[IMG]file:///C:/Users/bdeleon/AppData/Local/Temp/msohtmlclip1/01/clip_image001.jpg[/IMG]
captchaos
Mar 15, 2016 12:18 PM
wingnut2006
Sep 19, 2015 06:13 AM
jerrod99_se-l
Sep 6, 2015 08:58 PM
