Can you name this part?!
Old Mar 3, 2011 | 05:06 PM
High5maxi!'s Avatar
my old haynes manual says its a ball joint. but its not. it connects the steering rack to the strut/hub. its brownish in the pics. there is play and i think its causing my wheel to shake and viberate 0_o anyone got a part number or name so i can replace it?
Old Mar 3, 2011 | 05:16 PM
Stormzusmc's Avatar
lower ball joint
Old Mar 3, 2011 | 05:24 PM
High5maxi!'s Avatar
so the one directly under the strut is the upper ball joint?
Old Mar 3, 2011 | 05:49 PM
BenStoked's Avatar
Jesus was a Zombie.
outer tie rod end.
glancing at schematics, there's only one ball joint (aka, lower ball joint, lbj, or bj. no, homos) with mcpherson struts
tie rods are what rotate/swivel/etc. on a rack. the pic with the grease leaking out of the boot is the "outer tie rod"
inner tie rods are inside of the boot on the rack.
edit#34,395.
but technically, it is a ball-type joint.
Old Mar 3, 2011 | 05:52 PM
Stormzusmc's Avatar
is that what it is? mine looks different...if its off the rack then yeah tie rod end
id suggest running up to napa and have them pull up the diagram
Old Mar 3, 2011 | 06:48 PM
High5maxi!'s Avatar
Thanks! outter tie rod end. i shall get one tomorrow.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
