Lowered 2nd Gen camber adjustment
Old Nov 18, 2012 | 02:47 PM
86MaxWag's Avatar
For those of you that have a lowered 2nd Gen Maxima, were you able to get your camber set properly with factory cam bolt adjusters? Or did you have to purchase aftermarket camber bolt adjusters?
Thank you.
Ernie
Old Nov 18, 2012 | 04:18 PM
maximo018's Avatar
Thank you.
Ernie
Depending on how low you go depends on whether one needs camber bolts. I am currently running a set.
Old Nov 18, 2012 | 07:34 PM
86MaxWag's Avatar
Looks like I will need to find a set of lowering springs before I can find out if I need those adjusters.
Thank you for the reply.
Ernie
Old Nov 18, 2012 | 07:56 PM
chrome91's Avatar
anything 1.75" and lower will probably need a kit. i went 2.25/2.5" and never set the camber after, just eyed the toe. wore the edge of tires like crazy
Old Nov 18, 2012 | 08:07 PM
86MaxWag's Avatar
Hi chrome,
How was the ride with that much of a drop please? Did you keep bottoming out?
Thank you.
Old Nov 18, 2012 | 08:27 PM
chrome91's Avatar
i dont know if you live where it snows, but winter was brutal. everywhere i went in winter i would scrape and bottom out
summer wasnt too bad, on fresh speedbumps i had to crawl over at a angle and even then you could hear the exhaust just barely scrape sometimes. potholes and rough roads sucked too but that comes with the territory of being lowered. otherwise it handled awesome and looked good being that low
if you live where theres little to no snow, i wouldnt worry.
Old Nov 18, 2012 | 08:37 PM
86MaxWag's Avatar
I live near San Francisco but I still would worry about the potholes in the city streets. Would you have any pix of your car please?
Thanks for your input.
Old Nov 19, 2012 | 04:56 PM
chrome91's Avatar
dont have many pics left, this one was before it went to the junkyard hence no headlights etc. you can kinda see how low it is
other thing was the oil pan was a bit too low to the ground for comfort but it never even got a dent in it
Old Nov 19, 2012 | 05:33 PM
86MaxWag's Avatar
Thanks chrome!
Old Nov 20, 2012 | 09:32 PM
infinimax96's Avatar
While we're on the subject of lowered 2nd gens. Anyone have any pics of 2nd gen that has lower then a 2" drop? I'd love to see. I have plans on slamming mine in the near future.
Old Nov 20, 2012 | 10:16 PM
thetorp's Avatar
I just ordered my coils. I will in the near future
Old Nov 23, 2012 | 03:48 PM
What coils did you order?
Old Nov 23, 2012 | 05:22 PM
chrome91's Avatar
i think E-Dog was lowered more than 2"
Old Nov 23, 2012 | 08:10 PM
thetorp's Avatar
I got coilover sleeves. It will give me up to a 4" adjustable drop. I can cut the strut tube and reweld it if I want to go lower
Old Nov 24, 2012 | 12:49 AM
You should post some pics of the install. Do you have a link of the sleeves you bought? I might be interested in a similar set up.
Old Nov 24, 2012 | 12:56 AM
thetorp's Avatar
Yes Sir, http://www.ebay.com/itm/180739918504...84.m1497.l2649
I was told that the sleeves from a civic would work. Also one of my buddies suggested I use s13 coilovers. I do not have coilover money right at this point but I will be trying it soon. I def will post pics of the install on my build thread
Old Nov 28, 2012 | 02:56 PM
Any update on the sleeves? I want to install these KYB's I just need to know if sleeves are going to be a better choice then cut springs. If not I'll just slap the KYB's on with couple inches hacked off the springs until I get some s13 coilovers to mount to it.
Old Nov 28, 2012 | 07:35 PM
thetorp's Avatar
I am getting them tomorrow and installing within the next few days. The guy took so long to ship them.
Old Nov 29, 2012 | 12:01 AM
AllentownMaxima's Avatar
Is there anything like this for 4th gens? I mean sleeves or coilovers from another car that will fit a max?
Old Nov 29, 2012 | 12:28 AM
thetorp's Avatar
use ones for a civic or get cheap ebay coil overs.
Old Nov 29, 2012 | 08:33 AM
thetorp's Avatar
****ing package was delayed. I'm so ****ing pissed off
Old Nov 30, 2012 | 08:37 AM
same year civic? I can't find any ebay coilovers for a maxima
Old Nov 30, 2012 | 08:40 AM
all the stuff ordered on cyber monday is still being shipped out that's probably y it got delayed
Old Nov 30, 2012 | 11:09 AM
thetorp's Avatar
Yea its a 90's civic
Old Nov 30, 2012 | 10:46 PM
thetorp's Avatar
Got the sleeves today, I mocked them one up on a spare strut assembly I have, I have to do more cutting and grinding but that gives you a basic idea. I had to grind down the strut cartridge cap, I cut off the spring perch, grinded the welds so they were flatter/ cleaner looking, I would like to weld the sleeves on, I will probably do that. Here are some pics. Im my 2nd gen I have KYB AGX, they are from a MR2 and I cut and welded the tube to account for the shortness, a spacer could be used to accomplish the same thing.
Old Nov 30, 2012 | 11:40 PM
damnnnnn that actually looks ****ing legit. I might consider doing this since they are only $50 off ebay.
So is that the actual 2nd gen strut or is that the strut off a different car?
Just curious of how much fab work is actually needed to work with 2nd gen struts. I'll be putting these on 2nd gen Maxima KYB AGX's if It would work the same.
Old Dec 1, 2012 | 07:17 AM
thetorp's Avatar
It is a second gen strut.
Old Dec 1, 2012 | 09:36 AM
I'll be picking up a set of these then. That looks like it'll work for what I need.
Old Dec 1, 2012 | 01:18 PM
I think I might go with these 88-91 0-4" adjustable sleeves
they are marked for adjustment and allow up to 4" drop. I want as much low as I can get without sitting on bags.
Post some pics up when you get them on the Maxi. I want to see how it sits lowered at 3"
Old Dec 1, 2012 | 09:35 PM
thetorp's Avatar
I think that it will lower it a lot more. I have to measure but at it lowest point fully extended is way lower than stock.
Old Dec 2, 2012 | 11:12 PM
That's good to know. I hope to get this set up soon
Old Dec 4, 2012 | 07:52 AM
Matt93SE's Avatar
STFU n00b!
just because it says it can lower up to 4" doesnt' mean you should. totally FUBARs suspension and steering geometry when you go that low. You also run out of shock travel so you're running on the bumpstops all the time. car rides and handles like crap.
also note you'll quit likely run out of chassis travel. lowered 2.5", my 3rd gen rubs the inside of the front and rear fender wells under hard bumps. I destroyed my engine bay wiring harness once when it rubbed against my left side tire. had to repair the harness and reroute it so it was higher in the wheel well.
Remember, going lower brings a lot more complications than just scraping the pavement. Nissan's engineers didn't design the car to run that low, so you have to redesign a lot of the car to make that happen.
Old Dec 4, 2012 | 10:08 PM
I'm fully aware of all the implications you have brought to attention. That's why bags will always be a better choice for this circumstance. A complete redesign of the suspension on an air bag system will allow me to achieve whatever I want when I want it. But for now some coil sleeves will do just fine on this car.
I'm not much concerned about damaging a car that I wouldn't get much more then $600 for if I were to sell it. I'm doing it to have fun until I buy my next project car.
Old Dec 6, 2012 | 07:17 AM
TransAmBandit's Avatar
I hate my second Gen on S13 coilovers up front, lowering springs for a B13 in the rear (do not do this spring). Afterwards, I went back to stock springs cut one coil all around.
The S13 coilovers mounted up almost exactly. I used two front Cusco coils. They were old and one clunked, rode like ****. But it was great for a test fit and run. I had to slot one strut tower bolt, and cut the brake line tab off of the coilover body since it would hit the frame rail on full lock. I wish I documented this better, but it was last summer and it was hot when I did it.
The rear springs was a terrible idea, but for free I tried it. Blew the shocks in 5 miles.
Stock Height.
Cusco/Megan set up
Brand new KYBs with one coil cut all around
Old Dec 6, 2012 | 01:17 PM
This is the look I'm essentially going for. Maybe a tad lower. I have brand new KYB GR-2's ready for install. And I just ordered a set of the Civic coilover sleeves. I figure for $60, if I don't like it I can say **** it and put the stock springs on with some cut coils and call it a day.
So you didn't like the s13's because they rode like ****? What kind of coils were they and what condition were they in? If they were blown I can imagine them riding like crap.
Old Dec 7, 2012 | 07:10 PM
maximo018's Avatar
Gl man. Let us know how it turn out.
Old Dec 9, 2012 | 11:54 PM
Sorry, I meant to write that "I HAD my second gen on S13 coilovers" lol, the word hate was in my head the other day.
The coilovers were blown as I stated, Im sure with a good pair up front it would have been better. But ended up selling the car before I was able to put together a better setup.
Right now Im busy with my Cressida. If I get bored, I will be going back to a second gen.
Actually, my mind changes all the time. I want a second gen. lol
Old Dec 10, 2012 | 08:50 AM
I'd probably stick with the Cressida just because it's RWD. IF you did go back to a Maxima. Get a 1st gen.
Old Dec 17, 2012 | 04:39 PM
Well I got my sleeves and my KYB's but the sleeves don't fit over the KYB's. They are literally 1mm to small from being able to slide over the shock tube. I'm so annoyed right now.
So I was just going to cut the springs but when I went to remove the old strut assembly I couldn't get the bottom bolt out of the strut knuckle. I heated, PB'd and hammered the **** out of it. To no Avail, it wouldn't budge. I have work early in the morning and need the car so I opted to just put it back together for right now.
Not sure what to do at this point. Curse this car for being so stubborn.
Old Dec 17, 2012 | 05:08 PM
thetorp's Avatar
grind the **** out of it!
