Fuel Temperaure Sensor / Fuel Pump Regulator
ECU is giving me a code 41 (4 red blinks and 1 green blink in mode 3) = fuel temperature sensor. Both Haynes and the Chilton manual(s) state the fuel temperature sensor is attached to the (FPR) fuel pressure regulator which does not appear to have any issue as the car runs good (no stalling or sputtering). My questions are what effect does this code have on the engine, does this effect the emissions in any way and where can i buy a FPR with the fuel temp.sensor already attached as both manuals indicated it must be replaced as a unit. I tried autozone,Oreillys and NAPA but they only sell the FPR WITHOUT the sensor and no one seems to be able to locate a sensor. Any help is greatly appreciated....sorry for the long post
I had the same issue a while back and was able to find a part that appeared to be the same. I ended up going to a local pick n pull yard to get what I needed, but here is some of the information I was given in the thread I made
where in the hell can I find this
spencerwh1
Jun 30, 2016 05:44 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
Will this also work on a 2nd generation (87 Maxima)?
