Power Steering Fluid Overflow and Noise
Old Feb 17, 2026 | 10:02 AM
Edge's Avatar
Right after the cold weather the power steering fluid got air in it and overflows out of the reservoir along with the usual very noisy pump. Probably a hose or seal went out, so also I am checking the likely causes: reservoir suction hose to pump and clamps, return hoses and clamps. The pump looks dry with no leaks at the pulley shaft and body. No leaks the rack looking from the top side.
Does the oring on the suction inlet on the pump often go bad ? Any other things I should check?
knapp9
Apr 6, 2008 10:10 AM
Love_00_Max
Feb 22, 2008 07:08 AM
wyche89
Apr 10, 2007 06:24 AM
InfinitiJ30
Aug 7, 2006 08:30 AM
MSK
Dec 29, 2000 06:46 PM
