Water pump et al
Old Feb 21, 2002 | 10:00 PM
ricomartinez
Water pump et al
Okay, I'm new here and need to replace a water pump. Done this on easier cars (Porsche 924). I have already searched and read as many posts from the past. Can I please get some other questions answered?
I have pretty much decided to change the timing belt and tensioner. How much more difficult is this?
Is it easier to do this work with front end on ramps?
How hard is it to change the cam and crank seals?
Old Feb 22, 2002 | 05:50 AM
max95q's Avatar
cam crank seals I wouldnt know never done that. Timing belt and water pump, I would suggest going to a mechanic shop that has a great price. To me working in that cramped spot is very hard, how they do it I dont know. I had both my timing belt and water changed last year for 200.00. And they did a great job too. I would suggest going to a shop to do those. Oh and get the haynes manual on our cars and if you can get the factory manual for your yr car if you can, those will be most helpful with all your ?s you asked here. I have one.
Old Feb 22, 2002 | 09:59 AM
Charles Bisel
You should also change out your thermostat and your drive belts while your at it.
-C-
Old Feb 22, 2002 | 12:04 PM
Nismo87SE's Avatar
The cam/crank oil seals aren't that hard to replace. I'd say the hardest part is removing them, the FSM says to use a screwdriver and remove the seal. But in order to get the cam gears off you have to remove the valve covers and use some vise grips to hold the camshaft still. Or you could remove the camshaft rear plate and just have someone hold a ratchet on the otherside.
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
