V8 Swap
Old May 30, 2002 | 09:14 PM
butterbeandean's Avatar
V8 Swap
does any one know if it is possable to swap a v8 in to a 1982 max with out modifing the chissis ? if so how do you do it.
and yes i know there are mispelled words it's too late
Old May 30, 2002 | 09:25 PM
avalon42's Avatar
What V8 do you have in mind?
Old May 30, 2002 | 09:41 PM
289,302,305 or a small block 350
Old May 30, 2002 | 10:52 PM
avalon42's Avatar
Yes, stick with NISMO87SE's recommended Chevy 350, you shouldn't have any clearance problems.
Old May 31, 2002 | 08:39 AM
John L's Avatar
V8 swap
For weight reasons you may think about an aluminum block. Other possible contenders in the low weight, high output class: supercharged 3.8 Buick, Twin dual cam 3.4 Chevy, 4.3 Vortec. Just for consideration.
Old May 31, 2002 | 10:23 AM
thanks for the help. but what about the drive train (tranny driveshaft rearend)?
Old May 31, 2002 | 12:05 PM
John L's Avatar
gearbox etc,
With an auto, a 700R4, most likely, a manual, a t-5 would be my choice. You'd have to have a prop shaft fab'd. There is a r-drive bellhousing I have seen for the Chevy small 6, have to investigate further. Someone put a multi-port 2.8 in an early '70s midget and swapped out the original clutch slave. Looked pretty clean. A 3.4 will give you up to 220hp and less weight than the L-series. I just don't like the timing belt change procedure on that motor, but once it's in-line the way a motor should be, I suppose it would be alot easier. On the 3.8 side, I have a bellhousing for that I might be convinced to part with.
Old May 31, 2002 | 12:09 PM
Jeff92se's Avatar
I'm needing a caw
There are many V8 conversions available for the L-series Datsun Zs. Since the 82 maxima is basicly a 4 door Z, I would start my conversion search with one of the Z V8 conversions. Mostly likely a Chevy 350.
Old Jun 3, 2002 | 10:54 AM
rhayashi's Avatar
Rear wheel drive conversion
Are you guys insane??
to go from front wheel drive to rear wheel drive is not a option...
Old Jun 3, 2002 | 11:00 AM
Jeff92se's Avatar
I'm needing a caw
Re: Rear wheel drive conversion
If it were necessary to swap from fwd to rwd then you would be correct sir.
Old Jun 3, 2002 | 03:36 PM
Charles Bisel
I saw an old 1986 Cavalier that came stock with a FWD 4 banger and was swapped out with a 350 V8 and RWD, so on some cars it certainly is possible.
Old Jun 3, 2002 | 03:40 PM
Jeff92se's Avatar
I'm needing a caw
Ah the 1st gen maxima is already rwd.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
