2nd gen motor swap
Old Jul 4, 2002 | 10:18 PM
skold's Avatar
2nd gen motor swap
are there any engines that will fit into my engine bay - it's ALL stock right now... I want FATSER!! and kinda cheap if possible. hit me back if you know
e-mail: Skold1911@aol.com
aim: Skold1911
or just post back
Old Jul 5, 2002 | 01:41 PM
Nismo87SE's Avatar
Re: 2nd gen motor swap
VG30ET will fit, you'll have problems with the alternator mounts since it sits on the opposite side. That engine makes 200hp stock and can do 240hp wiht simple bolt ons. You will need a turbo ECU from a 85-89 300zx turbo and add 1 wire to the detonation sensor though. Everything else is straightforward.
aim: Skold1911
or just post back
Old Jul 5, 2002 | 01:56 PM
skold's Avatar
I appreciate the input man, i was wondering do you have any idea where i could start looking for those pasrt??
Old Jul 5, 2002 | 03:14 PM
Charles Bisel
Join the 2nd gen Nissan Maxima club at Yahoo, the link is posted in my sig. Go into the Bookmarks section, there you will find links to companies that support the 2nd Gen Maxima with parts and services.
Some sites that you'll want to check out include www.z31.com , www.nic-intl.com , www.jimwolftechnology.com , www.levelten.com , www.car-part.com
Z31.com will give you a lot of information about the VG30ET engine.
Nic International sells the VG30ET engine for a very good price.
JWT has turbos and they do custom ECU's and other turbo related stuff.
Level 10 does performance automatic transmissions which you'll need cause the stock tranny won't be able to handle the kind of ponies that a turbo puts out. I've even heard that you can't use a 5-speed with a high-output turbo because 3rd gear will get ground down smooth.
Car-part.com is a database of junkyards around the country, so you may be able to get some of the parts that you need for cheap.
If you do go through with the project, keep us updated on it.
-C-
Old Jul 9, 2002 | 08:15 PM
mike85gn's Avatar
I know I might get some flack for this, but we had an old '84 Maxima kickin' around and we're... umm... well me and some friends stuck a Chevy 350 V8 and Turbo 350 transmission in it. With a bunch of speed parts this motor dyno'd at 262.3 horsepower and 321.8 ft./lbs. of torque in an '84 Regal Limited. We're just finishing off the project now with a Holley 650cfm double pumper carb on top of an '87 Monte Carlo SS aluminum manifold. We're gonna take it out to the strip and see what it can do September long weekend. Hopefuly we won't blow up the factory driveshaft (3" shorter) and rear end. The fit is great and we've been going about two weeks so far, and hope to have it done by Friday. Too bad it's a hack job, you might not want to carve yours up like we did. But it's all in the name of speed and "WTF is that!!!"
Old Jul 9, 2002 | 09:53 PM
i_canoe's Avatar
-C-
Thanks Charles, you are a wealth of info. Thank You Sir
Old Jul 10, 2002 | 04:53 AM
Pervis Anathema's Avatar
Got pics?
Old Jul 10, 2002 | 05:17 AM
mike85gn's Avatar
Originally posted by Pervis Anathema
Got pics?
Yes, actually there are some pics of it in progress! I'll make them available to everyone shortly.
Old Jul 10, 2002 | 11:49 AM
Charles Bisel
I know I might get some flack for this...
Hey, as long as you're getting some major horsepower and speed, dropping in a Chevy 350 V8 is a great idea. I'd probably do the same thing if I had a first gen too. I mean, it's not like you're dropping in a Ford V6 or something.
-C-
Old Aug 19, 2002 | 07:45 PM
skold's Avatar
TT??
Would it be possible to fit something with a twin turbo in my Max?? or is there not enough space? Or would it just be better to go with the vg30et ya'll reccommended earlier?
Old Aug 19, 2002 | 08:34 PM
Nismo87SE's Avatar
Re: TT??
Dood you can so put a VG30DETT in there. Its only like $3-5k for the motor, then figure $300-1000 for the wire harness + ECU + Factory service manual. Then spend another $3k in fitting it and your done. You all the total $$, since you believe 2 turbos are better.
Finkle
Sep 27, 2015 09:53 PM
FlaMark
25
Aug 28, 2015 10:15 AM
ffcbairn
Aug 16, 2015 09:29 PM
criminalslang810
Aug 9, 2015 03:35 PM
