Lots of upgrades: 92 SE 5spd part out
Old Dec 14, 2009 | 03:09 PM
VE30DE POWER's Avatar
Well its final this time I have decided to part the car out everything is available minus the fuel pump, as this was the most recent thing to go out,so im done putting time and money in the car.
Info on the car.
Contact: either pm or minesevo5@hotmail.com
Car specs:1992 maxima SE 5 Spd VE30DE DOHC motor
black exterior,grayish black stripped cloth seats,black carpet,door panels etc.
On with the modifications.
Motor has been bored .20 over with 11:8 compression JE Pistons (if memory serves me correctly) with eagle rods.
Engine fully balanced
Crankshaft has been fully balanced and lightend
Heads,exhaust manifold have all been extrude and honed
Heads have been fully rebuilt. New (OEM valve seals, springs,retainers,valves,camshafts,lifters)
every seal,gasket has been replaced
new knock sensor
everything for the timing has been replaced new chain,sliders,tensioners,etc
For complete motor (From Intake manifold to Oil pan) im asking 1200.00 not including shipping If ya dont need the whole motor i will separate parts
Rebuilt Transmission...................................... ....... 300.00
Stillen lightweight flywheel.................................... 180.00
Stillen stage 3 kevlar clutch.................................. 150.00
Tokico struts eibach prokit springs all 4 corners........ SOLD
Suspension technique front and rear sway bars........ SOLD
Front Big Brake Upgrade 11.5" rotors 4 piston caliper w SS lines... 225.00
Stillen rear cross drilled rotors............................... 40.00 for both
Stillen short shifter........................................... ... SOLD
Stillen Intake............................................ 45.00 (could use a new filter)
Touring spoiler............................... 40.00 (local sale prefered due to size)
Greddy catback........................................... ........ 50.00 (had to replace greddy muffler so it basically just the piping from the kit new muffler sounds pretty close to it though. (local sale prefered due to the size etc)
Upgraded Y-Pipe......SOLD
Jim wolf ecu upgrade........................................... . 225.00
ASP alum underdrive pulley.............................. 50.00 (If someone buys the motor then this comes with it)
Canton racing high flow fuel and oil filter housing setup........... 125.00 (for both)
I'm sure im missing some things but ill post when i think of them.
For stock parts just pm me we can work out a price.
Parts are without shipping cost,but depending on what item you need that can change.
Link to some pics:
http://s65.photobucket.com/albums/h2...le/?start=all/
Videos of the car running/driving (remember it has no brakes):
http://www.youtube.com/watch?v=5UOv9baZMKo -walk around,idle/reving
http://www.youtube.com/watch?v=cP509sAZX5M -driving
Old Dec 14, 2009 | 03:50 PM
twtraudio's Avatar
how much for the steering wheel cruise controls shipped to 60404 ? Also how much for the tailights ? Also how much for the splash shield in the passenger front wheel well (the small one the covers the pulleys and belts) ?
Old Dec 14, 2009 | 04:08 PM
BenStoked's Avatar
Jesus was a Zombie.
pm sent re: toks/eibachs
Old Dec 14, 2009 | 04:36 PM
Mysticcal's Avatar
e-mailed. damn some good prices.
Old Dec 14, 2009 | 06:07 PM
dtfstock's Avatar
PM sent on door panels, carbon fiber stuff, and a couple of misc things.
Old Dec 14, 2009 | 07:25 PM
all pm's/email replied to. get back to me to let me know.
Old Dec 14, 2009 | 07:45 PM
dtfstock's Avatar
replied - thanks again
Old Dec 14, 2009 | 09:13 PM
mrkanda's Avatar
Taking my Maxima to the Max!
How much for the whole car, everything included? I'm not far from you.
Old Dec 14, 2009 | 11:37 PM
sb_max510's Avatar
window visors
do you have the other 2? how much shiped to 94801
Old Dec 15, 2009 | 09:31 AM
Maximan190's Avatar
Sway bars - what condition are they in, new/used? Does it include the bushings and mounting plates (rear), links (front) and hardware?
ECU - again same thing is it new/used? Is it the entire ecu unit or a separate plug in board (not sure how these are set up)
Old Dec 15, 2009 | 11:06 AM
no i only have the 2 front window visors. 22.00 shipped.
sway bars are used and in great condition,yes it will include everything needed to install
used,its the entire factory ecu. No plug in board
Old Dec 15, 2009 | 11:59 AM
biggz2332's Avatar
do you have the cup holder??
Old Dec 15, 2009 | 12:25 PM
Maximan190's Avatar
Just to confirm - this is the Jim Wolf ecu i was asking about
You have any pics of each? (sway bars and JW ECU)
thanks
Old Dec 15, 2009 | 01:07 PM
oh sorry man skipped right past ya,let me look when i get home.
thanks
Yes I know as this is the only ecu i have
I can get pics just gotta wait til i get the car in the garage so i can jack the car up.
Old Dec 15, 2009 | 02:52 PM
James92SE's Avatar
2 VE's are better than one!
Yeah, the Jim Wolf is actually a daughterboard (or something rather) added on "internally", so the actual ECU itself doesn't look any different visually outside (although it should have a sort of generic Jim Wolf sticker and an "illegal in CA" type of deal) . I'm sure if you took the casing apart you'd notice it, though.
Also, dew eet!
Old Dec 15, 2009 | 03:44 PM
biggz2332's Avatar
Ok let me know!
Old Dec 15, 2009 | 07:00 PM
damax's Avatar
Please send pics of spoiler, y pipe, and rotors.
Old Dec 16, 2009 | 12:04 PM
Augustus Maximus's Avatar
Waiting for reply from PM
Old Dec 16, 2009 | 07:50 PM
For everyone who is wanting parts.Ill be starting to take parts off this weekend so give me til then,this way i can take pics of your parts. Also check out the link in thread it has pics of most parts everyone is asking about.
PICTURES
Old Dec 17, 2009 | 06:28 AM
dtfstock's Avatar
Thanks for the update.
Old Dec 17, 2009 | 07:52 AM
twtraudio's Avatar
awsome thanks for the update as well !
Old Dec 20, 2009 | 07:15 AM
All PM's replied to with update.If needing bigger pictures you can go here.
http://s65.photobucket.com/albums/h2...ale/?start=all
Old Dec 20, 2009 | 05:37 PM
dtfstock's Avatar
Thanks for the additional pictures, PM replied to.
Old Dec 29, 2009 | 08:26 AM
updated parts list.
everyone has been replied to and your parts are sitting in boxes ready to be shipped,just waiting on your reply.
Old Dec 31, 2009 | 06:19 PM
BenStoked's Avatar
Jesus was a Zombie.
updated parts list.
you have money.
Old Jan 5, 2010 | 09:24 PM
Got it....thanks bro.
Old Jan 6, 2010 | 12:02 AM
Max_5gen's Avatar
Do you have ebrake cables?
I also need one wheel.
Alternator?
Injectors: are they for sale and what condition?
Driver side door trim/seal pieces marked with red arrows on those pictures:
- door piece
- body piece
Old Jan 7, 2010 | 04:47 PM
92-max91-240sx's Avatar
do u still have the gauge cluster if sp how much
Old Jan 7, 2010 | 09:54 PM
maximo018's Avatar
How good was that short shifter? If its worth it I'll take that off your hands. Let me know asap so we can make transaction and I can get it before it goes to someone else.
How the hell I missed this a few weeks ago Idk. By the way enjoyed your old video on youtube.
Old Jan 9, 2010 | 11:16 AM
I loved it very well built piece throw was short and direct,no slop.Just move your wrist and your in the next gear.
All pm's replied to as well..
Old Jan 9, 2010 | 07:21 PM
CMax03's Avatar
Is the engine assembly still available? What kinda power were you making at the wheels?
Old Jan 11, 2010 | 05:54 PM
maximo018's Avatar
I'll take that shifter off your hands. Let me know if you still got it.
Old Jan 24, 2010 | 02:30 AM
maximo018's Avatar
Man did this thread die or what?
Old Jan 24, 2010 | 07:54 AM
torontomaxi's Avatar
If this guy is around I need the FUEL PUMP, WINDOW MOTOR, and WIPER MOTOR
Old Jan 24, 2010 | 07:12 PM
VEvolution's Avatar
I miss my VE
which door on the window motor?
Old Jan 25, 2010 | 09:10 AM
VE30DEPOWER's Avatar
For the fuel pump thats a negative, got the wiper motor, and like VEvolution said which one do you need.
Yeah im still here just been working in the background getting peoples parts shipped and stuff.
Old Jan 25, 2010 | 07:53 PM
maximo018's Avatar
Is that shifter and engine plate still for sale?
Old Jan 26, 2010 | 12:21 PM
MaximaFan4140's Avatar
how much you want for those tail lights shipped to 28304?
Old Jan 28, 2010 | 04:09 PM
ebaker's Avatar
Does the transmission have the locking diff? Still available? Do you have the oem radiator fans?
Old Jan 29, 2010 | 01:14 PM
Originally Posted by ebaker
Is the transmission have the locking diff? Still available? Do you have the oem radiator fans?
yes the transmission does have a locking diff, I have the fans as well but im holding onto them for a project
