What causes this whinning noise when in gear?
Old Jul 15, 2002 | 04:33 PM
cui's Avatar
cui
1990 GXE...it has this weird "whinning" noise when put in gears.
(all gears, including reverse)
the max drives fine and had the transmission replaced 15 months ago.
My friend (who is a mechanic...but he does not work on maxima) thinks it is the oil pump...but I am not too sure...because the noise can only be heard while in gears...
There is no noise while in P or N.
thanks in advance,
Old Jul 15, 2002 | 06:56 PM
CanadianMaxima's Avatar
my car was making a horrible whining sound and it turned out to be that the power steering resevoir was basically bone dry. the whining was there all the time even while in P and N so i'm not sure if this would apply to you. just something easy to check.
Old Jul 16, 2002 | 09:05 AM
cui's Avatar
cui
thanks CanadianMaxima,
It is not the pwr steering pump reservoir...I checked all fluid...everything is full...except the transmission appeared to be over-filled.
I never know the true level of the transmission fluid...all the cars I owned, they all appeared to be over-filled...(ie, above the H mark even when the car is cold.)
Should this be a concern?
Old Jul 16, 2002 | 10:57 AM
you also checked it when the car was on at operating temperature right? if i'm not mistaken i think the car should be running and at operation temperature when you check the fluid level. anyone wanna verify this?
Old Jul 17, 2002 | 08:44 AM
cui's Avatar
cui
I am going to remove all the drive belts (ac, alternator, and ps)
and see if the noise continues...
next I guess I should check the exhaust manifold? something is definitely making noise under load (even the load is light)...
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
