rebuild difficulty
Old Jul 27, 2002 | 05:25 PM
surfermax92's Avatar
rebuild difficulty
I have done a bit of research on how to rebuild the vg engine, what parts to put in, and so on. My problem is inexperience. I've never done internal engine work. If I had an extra vg30 that I kept on a stand, and the right tools, would it be possible for a newbie like me to break down the engine, have some parts machined, and then put it back together with new parts? The reason for this is that I really want to learn as much as possible about the engine, while making it faster. I would of course buy a FSM and have the actual engine swap done by a shop. Thanks for any help, Miles
Old Jul 27, 2002 | 06:21 PM
Nismo87SE's Avatar
Is this going to be a project or repair? Otherwise it would be more cost effective to buy a used VG30E. Once you get the FSM and the engine stand all you will need to tear the motor down is the proper tools. If you have a spare engine that is the best way to go. Also make sure you read the FSM at least twice all the way through in the EM section. That way you have a great idea of what your doing and you won't miss something as easily.
Old Jul 27, 2002 | 07:49 PM
davis4005's Avatar
Anything can be done with patience and the right instructions, I would love to rebuild a VG. Good luck man, and let us know how it goes if you do it.
Old Jul 27, 2002 | 11:17 PM
it's for a project, and I plan to buy a used vg30e, motorsport 280 cams, vg30de pistons and a JWT ECU, and swap them in. Where I am a little hazy is what to do about the other parts. I seem to remember that the vg30e internals are forged, and that all I would have to do is have them balanced, and they would be good for 7500 rpm. I would also replace the seals and gaskets and port and polish the heads and maybe intake and exhaust manifolds. Then bore out the throttle body and put it back together. I think that Turbo95max will put the new engine in, and I should be set to go. Any flaws in this, or something that I should be doing? (btw, this is what I gathered from reading every engine swap post in the forum )
Old Jul 28, 2002 | 02:58 PM
Agamemnon's Avatar
Don't forget the right tools!
There's a saying that says "Having the right tools is half the job." And I believe that's true.
Old Jul 28, 2002 | 07:58 PM
Nismo87SE's Avatar
don't forget you will need higher rev valve springs and retainers. I believe motorsport or ISKY sells the higher rev valve springs/retainers.
Old Jul 29, 2002 | 06:04 AM
Shadow1198's Avatar
Large Member
If you have the money, I'd try to spend a little more on the internals and then you'd get greater benefits. I seem to remember someone getting titanium rods from some place (I might be wrong). Also, if you got some pistons that bumped the compression ratio up to about 10.5, it would help a lot too. You can also have both manifolds and the heads extrude honed and ported. Though, the VG heads are already pretty good. All these little things can really help to get some good horsepower out of the engine.
Old Jul 29, 2002 | 12:28 PM
I think that the vg30de pistons will give 10.5:1 compression, but I'm not sure. As for titanium internals, I am trying to stay away from custom parts- as they cost mucho $$. If I was ready t spend that much money I would go for the vg30et swap. I will definitely look into the porting and polishing and extrude honing, but what parts should I do that for? Intake manifold, exhaust manifold and heads?
James92SE
142
Jan 2, 2024 09:23 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
jcvgn
Sep 10, 2015 08:03 PM
