More power??
Old Aug 2, 2002 | 07:19 AM
Terry28's Avatar
More power??
Guys i think my headlight has low power and so does my corner because i installed the fog lights and the sidemarkerlight and the windshield washer light so i think i am losing power and my headlight is not bright and i even bought a white 80 bucks bulb to get it bright but i think it stll the same so is there anything i can do to make the poer more like is there any parts that i can replace with aftermarket good part that wiil increase power, plz help.... Thanks in advance....
Old Aug 2, 2002 | 06:47 PM
RosenKen's Avatar
is one headlight dimmer than the other?
Old Aug 2, 2002 | 09:48 PM
Terry28's Avatar
no they both are the same before even with the stock bulbs they were bright but then they both were getting dimmer so i bought the white 80 bucks bulbs and tried that but i see no different and nothing is wrong with the bulbs cause i tried it in other car and it is very bright but not bright on my car.. so how can i make it bright is there any electric parts or something?.Thanx..
Old Aug 2, 2002 | 10:07 PM
mykizism's Avatar
its because the maxima headlamp is probably old
its not clear like the newer cars and the way its designed (refraction glass) absorbs a lot of the light... and the reflective housing inside the headlamp is probably degrading.
RosenKen's Avatar
So both lights just went dim at the same time and stayed like that? Sounds like you fried your headlight wiring harness. What was your bulg rating in watts? 100W? Check the wires you plug into the headlight bulbs and see if they're burnt or melted.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
