Cruise/Fog/Power mirror switches
Old Aug 3, 2002 | 09:49 AM
MagicSmore's Avatar
I *did* do a search on this first and found some info, but I don't know if it's gonna help me any..
The problem is that my dimmer switch and rear defroster switch light up at night. However, the cruise, power mirror, and foglight switches don't. I don't think it's a blown fuse, because then all of the lights would be out, right? But it's just the ones to the left of the steering wheel...
Now in my search, I ran across a guy who had broken the bulb inside one of his switches. I suppose this could be the answer, but I wanted to make sure there's not something else that could be the problem.
Old Aug 3, 2002 | 11:08 AM
nstymax93's Avatar
You know i have the same problem except none of min light up except for the power mirror switch and my dimmer switch doesn even dim the lights. I checked the bulbs but they looked fine. Should i go ahead and replace them anyways?
Old Aug 3, 2002 | 11:20 AM
Michael's Avatar
Back in a 3rd Gen.
you can take them out and go to radio shack and buy the little mini bulbs to replace them with. Do your search on mini bulbs or something like that maybe add radio shack into the search. Craig posted the part numbers for these bulbs in one of those threads. I got some before but I am sorry I cant remember the part numbers.
oh and dont worry the bulbs from radio shack are a little smaller than some of those bulbs but they work fine.
Good luck.
nstymax93-yes replace them...I had a lot of those bulbs that went out (6 all to gether I think) and all of the bulbs I pulled out looked fine even though they didn't work.
Old Aug 3, 2002 | 10:05 PM
«§»Craig B«§»'s Avatar
272-1092 I think
12v "minilamps" from radio shack
even the small radio shack at our mall had these last time I was there
search for more info
Old Aug 4, 2002 | 09:05 AM
Dave S's Avatar
Originally posted by «§»Craig B«§»
272-1092 I think
That's the correct part number (I still have some left).
Old Aug 4, 2002 | 10:01 AM
GRNMAXDMON's Avatar
i know this is out of the question but i really need to know if any of u guys know what kind of bulbs does ngthing have behind his gauges. i really like how it lights up. i wanna put those bulbs cuz i just installed the SE gauges in my car but i wanna make them brighter and i saw ngthing's and i wanna know what kind of bulbs they r and where i can get them and if u guys know the part #???
thanks in advance,
Rick
Old Aug 4, 2002 | 08:00 PM
ThurzNite's Avatar
yup yup...swapped out the ones for the AC panel...i'm 1/2 done with the writeup with pics...i don't like html!
Jae
Old Aug 5, 2002 | 10:19 AM
nstymax93's Avatar
my a/c heater controls wouldnt light up either and i looked at radio shack and their lights did fit completely so i went to nissan and bought the lighs and they were $6 a piece and i need 2! EXPENSIVE!!
Old Aug 5, 2002 | 12:31 PM
Clayton's Avatar
Yeah very easy to replace those little bulbs. I've had to do my side mirror defroster switch and the Power/Comfort tranny switch.
However, The bulb on my cruise control button doesn't work anymore, but my cruise control works fine, and it doesn't look like you can get to that bulb without completely disassembling the entire switch. Anyone ever replace the bulb for that one? If so, I'd love to know how you did it.
Old Aug 5, 2002 | 01:59 PM
for cruise and a few other switches, you'll have to remove the switch, then pop the cover off it (and watch where all the little pieces inside go)
once it's open, you can see how the bulb goes in and just replace it with a new one
Old Aug 6, 2002 | 07:32 AM
Clayton's Avatar
I don't know if that's worth it for the cruise control button, but good to know it can be done.
Old Oct 19, 2002 | 11:29 PM
Agamemnon's Avatar
I've just finished replacing all the burned out bulbs in my dash buttons (fog, dimmer, cruise, defroster, mirror heat & those fresh air toggle thingie on the left of the heater controls). Now my dash lights up at night like Tokyo Bay at night once more! What a beautiful sight...
Anyway, the process was more painful than I expected. It seems that every two bulbs I replace, one more failed to light up. I had to take apart the dash panel and put it back together three times! Also, everytime I had to take apart one of the switches to access the bulb inside, they seem to like to 'explode' open sending parts flying everywhere. I had to guess how to put them back together again. Murphy's law rearing its ugly head... Thankfully all the switches worked now, so I must've guessed right!
BTW, they all use the 272-1092 bulbs. In the end I had to buy 10 of them (5 packs)! Also if anyone's interested in doing the same, I suggest having a needle (or something equally small) nearby to help remove the old bulbs from their rubber sockets.
Oh, also the power mirror lights does not seem to be lighted, as there's no evidence of bulbs (or places to put them in) behind the L/R marking.
Old Oct 20, 2002 | 10:50 AM
redzero's Avatar
gxe's would use the same bulbs right?
the 272-1092
Old Oct 20, 2002 | 06:52 PM
the 272-1092
yes
Old Oct 21, 2002 | 09:05 PM
drstillpatient's Avatar
bulbs changed!
i was in the middle of resoldering the clock on my Max when i came across this thread...so i said hey why not....
i had 4 switches that would never light up...i got em all done...even the Hazard switch...piece o'cake.
yeah they tend to scatter parts all over the place once u open the switches, but they're prety easy to assemble back
the needle was definitely helpful...
NEXT STEP= i will try to change the entire illumination inside the dash to red..just like my aunt's BMW 5 series ...i just need to find some red bulbs instead of plain old transparent ones....anyone has any ideas or suggestions where i can find some?
thanks
Old Oct 21, 2002 | 09:15 PM
Re: bulbs changed!
thanks
I dont know if that's gonna be very easy to do. I'm pretty sure most of the bulbs didn't have any "condoms" or anything covering them. They are originally white but then the translucent part of the switch is tinted and gives them the color.
I could be wrong, but I think that's the case.
Old Oct 21, 2002 | 10:10 PM
yeah craig....i have the defog switch and the cruise control switch open in front of me and they have an independent piece of green "tinted' transparent plastic behind the face of the switch that gives it the green color...
it does look difficult to get them out...but if i can find red tinted plastic somehow....or red bulbs, i'd take the green pieces out!
i'm gonna keep looking
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
