Pcv Problems
Old Aug 3, 2002 | 10:24 AM
maxipriest's Avatar
Pcv Problems
Does anyone know the symptoms of a bad PCV valve?
Any Help would be hot
Thanks Fellas.
MAXI
Old Aug 3, 2002 | 10:59 AM
karguy's Avatar
Re: Pcv Problems
[QUOTE]Originally posted by maxipriest
[B]Does anyone know the symptoms of a bad PCV valve?
PCV valve draws off bypass gases so pressure does not build up in crank case. If it were stuck open it could cause erratic idle and if stuck closed oil leaks. It is very easy to get it out and replace,
clean or check it for operation. It is basically a one way check valve and cost about $3.00 at a parts store.
Old Aug 5, 2002 | 04:42 AM
SmithAtlanta's Avatar
Re: Re: Pcv Problems
[QUOTE]Originally posted by karguy
[B]
Maybe easy on a VG but not easy on a VE.
Old Aug 5, 2002 | 07:06 AM
DAREN's Avatar
[B]
i am suffering form an oil leak problem on my VQ, the last mechanic i spoke to said it might be a PCV problem. mt quesion is can a partially blocked catalytic converter or y-pipe cause the same problems.
Old Aug 5, 2002 | 07:29 AM
karguy's Avatar
Re: Re: Re: Pcv Problems
I don't think they would cause the oil leak but would cause all kinds of performance problems~
Be well!!!!
Old Aug 5, 2002 | 09:55 AM
In the service manual, the 2 possible side effects of having a bad PCV Valve is inconsistent idling and oil leaks. I don't think that installing a new PCV valve will fix the oil leak but(after you repair the oil leak) it will help keep an oil leak from happening again.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
homewrecker
Sep 24, 2015 07:01 PM
