working on brakes.. got a question
Old Aug 3, 2002 | 05:02 PM
pezking4's Avatar
I'm starting a new thread, because I'm in the middle of working on the brakes right now and I need to know something ASAP. I'm trying to compress the piston with a C clamp but it won't budge, is there a trick to doing this? The only experience with brakes I have is on a 74' vette, so I was just doing it in a similar way. Let me know what you guys think. Thanks.
Old Aug 3, 2002 | 05:20 PM
Tim93se5sp's Avatar
If you are doing the front brakes, pushing the piston in with a C clamp should do the trick. If you are doing the back brakes, however, they need to be screwed in. You can use a special tool, or a good wrench to turn the piston in a clockwise direction. Just dont mess up the rubber seal around it. If that doesnt seem to work, a little pressure with the C clamp while you screw it in should do the trick (thanks Matt).
Old Aug 3, 2002 | 05:39 PM
pezking4's Avatar
yeah, I'm doing the back brake right now. No such luck yet.. but I'm working on it.
Old Aug 3, 2002 | 07:27 PM
pezking4's Avatar
Ok, I finished with the back brakes, and I'm going to do the fronts tomorrow when there is more light. The only question I have now is are the brakes going to self adjust and know how much to apply. The reason I ask this is because I would spin the wheel with my hand and hear the sound of metal on metal, so I'm trying to figure out if the brakes are actually partially applied when I put the assembly back together. I hope this is a good discription, I think so far everything has gone well for a first time brake job.
Old Aug 3, 2002 | 07:56 PM
Maximajism94se's Avatar
after u complete the job, u r supposed to pump your brakes a few times b/f rollin down the road...that will seat the pads in the right spot
Old Aug 3, 2002 | 09:20 PM
pezking4's Avatar
Thanks for the advice. Everything felt normal with my 5 mph stop in the drive way as I was putting the car away for the night. Oh, the brush attatchment on the drill worked well to get the calipers shiny again, it also works well to bloody your knuckles if you get your hand to close to the drill. I can't wait till I have something besides these stock rims so people can actually see the rotors too.
Old Aug 5, 2002 | 06:42 PM
pezking4's Avatar
Just as an update, everything works fine and I noticed my next weekend job while I was working in the wheel wells. The axle boot is ripped on both sides in the front and there was axle grease thrown all over the place under there. Time for me to start researching how I'm going to fix this problem.
Old Aug 5, 2002 | 07:22 PM
D-sta's Avatar
Lots of info on the axle stuff. SEARCH!
Old Aug 6, 2002 | 11:49 AM
Matt93SE's Avatar
STFU n00b!
on the rear discs, apply the parking brake a few times to seat the rear calipers. that's all the adjustment you need back there.
also be sure to bleed your brakes. if the fluid is more than a couple years old, you'll see a huge improvement in braking by doing that.
also time to buy new CV joints. you could buy the boots alone, but a complete new set (4 boots- 2 inner and 2 outer) will run about about $70. reman axles are about $60 each with lifetime warranty.. simple decision there. another $50 to get a lifetime warranty on both axles? go for it.
be sure to buy enough tranny fluid to change everything over and also replace your axle seals.
entire job should cost around $150 for parts.
Old Aug 6, 2002 | 01:40 PM
pezking4's Avatar
thanks matt, I'll be working on that next. I guess I'll have to hold off on the CAI and fix this problem first. How hot are rotors supposed to get? Maybe I was just being dumb, but when I got done driving through town today I was trying to inspect them and I touched my front rotor and it burned my finger really badly... like 2nd degree burn badly. Does this sound normal? If so, don't ever be dumb enough to touch your rotors after driving!
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
doobadoo
Aug 15, 2015 06:43 PM
kenc15
Aug 5, 2015 08:29 AM
