Ground points on a VE
Old Aug 4, 2002 | 09:21 PM
poorcollegeboy's Avatar
Does anybody know where all the grounding points are for the VE engine? Anybody has a FSM? Thanks!
Old Aug 5, 2002 | 10:18 AM
blackandwhite's Avatar
To them I'm like an idol
Re: Ground points on a VE
I've got the '93 FSM, but I have no idea where (or what for that matter) the grounding points are. If you can tell me where to look, I'll try to find it for you though.
Old Aug 5, 2002 | 12:16 PM
Re: Re: Ground points on a VE
i think somebody on the general maxima forum said it's in the EL section.
Old Aug 6, 2002 | 11:23 AM
eric93SE's Avatar
What you should do is follow the wire leaving the neg on the batt. You will see that the wire goes straight down and bolts to the fender, that same wire then continues and travels over to a point on the engine block. There is another ground wire that I'm not sure where it comes from (probably from the block) and it ends at a point directly under the stock air box (so it would be very convenient to remove the air box to get to it). On the opposite fender (passenger side) there is a ground wire for the lighting system, this grounding bolt points stright up and is next to the filler neck for the wind sheild washer fluid.
You should also clean the possitive and neg connectors that are on the alternator. You should be carful when removing the pos connection on the alternator so that it does not touch another metal surface or the body of the alt itself (ideally you would disconnect the neg on the batt when doing this).
I have already done all the connections in my car long ago, but this is something that should be done every couple years.
Old Aug 6, 2002 | 01:53 PM
ThurzNite's Avatar
I was looking at my 93 SE and found the 2 points leading from the neg battery terminal. 1 is on the fender, the other is on the block. I was also thinking of the Alternator. I can't think of any other place and the nissan parts manual doesn't help.
Jae
Old Aug 6, 2002 | 02:06 PM
ThurzNite's Avatar
woohoo!!! found another grounding point!!!!
1) fender by battery
2) front of block
3) alternator?
4) ??? <--will post pic in a sec.
Jae
Old Aug 6, 2002 | 02:34 PM
ThurzNite's Avatar
1) everybody knows this one by the driver side fender:
http://autos.werd.com/thurznite/pics...B/DCP_0024.JPG
2) And if you follow that wire, it leads to the block:
http://autos.werd.com/thurznite/pics...B/DCP_0023.JPG
3) I didn't go under the car for the pic of the alternator, but it's there
4) and the one we've been waiting for:
http://autos.werd.com/thurznite/pics...B/DCP_0025.JPG
The first person who posts the exact location of the grounding point found in my picture will receive a free cell phone antenna booster! Good luck!
Jae
Old Aug 6, 2002 | 02:47 PM
ThurzNite's Avatar
Re: Re: Re: Ground points on a VE
well, i don't have a fsm for my 93 max...i was gonna get one, but someone outbid me on ebay. haha
still, it's fun to play hide and seek with those grounding points!
Jae
Old Aug 6, 2002 | 02:53 PM
Jeff92se's Avatar
I'm needing a caw
Wow nice pics. When I was putting my engine back in, I apparetly forgot to connect one of the wiring harness grounds. It grounds to one of the valve cover bolts. I didn't notice a difference in performance but when I touched it to a ground, it sparked. So needless to say, I reconnected it. I think the ignition system signal wires to the coils need a good ground.
Old Aug 6, 2002 | 03:03 PM
MrGone's Avatar
Jae
So your hood struts are bad also hunh. sucks doesnt it. well i put my broom back where it belongs since my 3rd isnt living anymore. I used to prop the hood up with an old broom.
MrGone
Old Aug 7, 2002 | 12:28 AM
ThurzNite's Avatar
MrGone
isn't a broom kinda long?
I just noticed...when the temp's warm or the engine's warm, the struts suck. but when it's cold like in the morn, the struts are great (for 5 min...then it falls on my head!) Kragen sells the struts for about $30 each! ouch!
Jae
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
