New KYB strut porblem!
Old Aug 8, 2002 | 06:42 AM
nstymax93's Avatar
I just put on KYB struts for the front and took it to the alignment shop. They called and said i have a such a negative camber on the left strut that they have to slot it. Does anyone know exactly what that is? Will it hurt the car or struts? I hate this alignment shop but they are the only ones i found that will align lowered cars.
Old Aug 8, 2002 | 09:01 AM
Lordrandall's Avatar
It means they drill out the mounting points on the strut a bit so they can get the camber in spec.
Old Aug 8, 2002 | 09:09 AM
D-sta's Avatar
Is that good or safe at all?
Old Aug 8, 2002 | 01:46 PM
male's Avatar
Safe as long as they don't remove too much material. What springs do you have on there? If you are getting that much neg. camber, I would think there is something else going on. Has your car been hit before? Worn ball joint, control arm bushings, strut mount? Just some ideas. If you are only getting it on one side, I would really look into the condition of left side parts..broken, bent worn etC. Slotting the strut would be a last resort if I were in your position. But I don't think it would be unsafe, but it might mask another existing problem.
Old Aug 8, 2002 | 06:04 PM
93maxVG's Avatar
Real Quick, where did you get the KYB's??
Old Aug 8, 2002 | 06:07 PM
KLoWnPR109's Avatar
you can get them at www.shox.com and www.eatricezone.com
I got them at EatRiceZone for 186 plus shipping
Old Aug 8, 2002 | 06:12 PM
nstymax93's Avatar
Got them at www.bestforeignparts.com for $47.88 each for the front and $36.94 each for the rear which is $169 for all 4 but then add shipping! Pretty cheap!
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
