Window Jammed/ Just Replaced the Regulator
Old Aug 10, 2002 | 12:29 PM
JoJo428m's Avatar
Okay, When I replaced my regulator (using Craig's How-to)all the wires were really just messed up, so I replaced it using the original motor and harness, but now it's jammed or something. It's a big Pain in the @ss but I can't figure out what's wrong....Could it be the motor, cuz I did get impatient and accidentally broke one of the screwholders Or should I check for stray things rumblin around in there?
Old Aug 10, 2002 | 01:42 PM
rbloedow's Avatar
Re: Window Jammed/ Just Replaced the Regulator
Make sure that the window is in the rubber tracks on each side of the door. I originally made that mistake, and the windows would only roll up half way. I had to disconnect the regulator/motor, and reseat the windows so that it was in the tracks.
Old Aug 10, 2002 | 01:46 PM
James12345's Avatar
Re: Re: Window Jammed/ Just Replaced the Regulator
I did the exact same thing. It's easy to get the window slightly off in the tracks and makes you wet yourself cuz you think you effed up.
tilt's Avatar
It's possible that you got the window mount on wrong... it will make the window hard to move up and down. I would take it apart and reinspect your work. Also, do you hear the motor kicking in when you flip the switch?
Old Aug 10, 2002 | 04:10 PM
91SEMAX's Avatar
Does the window motor sound like it's straining when you try to move the window?
Old Aug 11, 2002 | 04:43 PM
JoJo428m's Avatar
I went out again, and it worked fine and crapped out, so i took out the regulator/motor, and the regulator wasn't moving, and I went through process of elimination, and the motor isn't turning any more
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Superbform
Aug 11, 2015 08:10 PM
