Audio System Question
Old Dec 15, 2000 | 07:10 AM
PrinzII's Avatar
OG and counting...
I have read a lot of the posts on the board regarding problems with the Bose and aftermarket head units. My concern is that since I have the "Active Speaker" system, could I connect my Eclipse 4441 to these stock speakers without worrying about the impedance or would I have to shell out more dough to put some new speakers in my car?
Old Dec 15, 2000 | 03:23 PM
Brandon90gxe's Avatar
i have a kenwood deck hooked up to the stock speakers, and it sounds pretty decent. It really needs a sub though.
Old Dec 15, 2000 | 03:46 PM
amax935's Avatar
go for it
I am pretty sure that you will have no problem, but be forwarned, once you get started........................................... ......
Old Dec 15, 2000 | 04:21 PM
Chris Gregg's Avatar
Get Off My Lawn
If you have an Elipse, I'm thinking that you are going to be really disappointed in the sound that you hear from these speakers. Speakers get old, like anything else, and wear out. If you've got the dough, upgrade your speakers, you'll be a lot happier and doing this is really easier I think. Install new deck, run RCA's to the amps in trunk, run speaker wire to front speakers (easy, just run through rubber in door with rest of wires) and the speakers in the rear are easy to run wire to! Your call....
Old Dec 17, 2000 | 05:54 AM
Jaybird180's Avatar
I agree that it is relatively easy. However, don't use most of the references that tell you that you have a 6x9 setup in the rear. Most likely it's a 6.5 like I had in my active speaker system. After acquiring some 6x9's I went to the local salvage yard and got some brackets from another 3rd gen. Took out my rear shelf package removed the speakers and installed the new ones (Eclipse). They sounded really crappy at first, then I realized that I had a phase timing error, for which I corrected (reversed the wires). Now life is great.
Now if you are using an aftermarket head, I was under the impression that it may be wise to bypass the factory clarion amp located on the underside of the trunk. Can someone please comment on this.
Old Dec 17, 2000 | 10:13 AM
Cincy94Max's Avatar
clarion amp bypass
http://24.1.29.190/blehm/maxima_stuf...p%20bypass.txt These directions are from Matt93GXE and he knows what he is talking about.
Old Dec 17, 2000 | 11:22 AM
block's Avatar
From what I know you cannot use the bose speakers, because they are 2ohm and it will fry your HU.
9aj9
Apr 5, 2020 12:11 AM
dcam0326
Sep 7, 2015 07:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
